Hi Brijesh,
It still seems to lockup with that command as well. This is the message its spits out when it happens:
select 1 (init), adj 0, size 52, to kill
select 1742 (dbus-daemon), adj 0, size 62, to kill
select 1747 (hald), adj 0, size 240, to kill
select 2043 (gst-launch-0.10), adj 0, size 12930, to kill
send sigkill to 2043 (gst-launch-0.10), adj 0, size 12930
Another question I have is, if I kill the video early with CTRL + C how do I get the console back on the screen. I have looked through the /sys/devices/platform for a way to get it back but I have been unsuccessful. The stopped just remains on the display.
Kevin
Kevin,
Are u using latest .dev branch for building gst-ti ? I think it may be
better to first ruleout any display sink problem. Have u tried using
"xvimagesink" or "omapfbsink" etc ? What happens if you use fakesink ?
Does decoder gets blocked.
In addition to this, there are some known issue with DSPLINK and
CTRL-C combination hence i tried to avoid hitting CTRL-C during
playback. Instead u have gracefully transition from READY->NULL using
gstreamer application programming. If you get gst-launch in defenc
state then first "reboot" is the only option for now.
Brijesh
Brijesh,
This issue is due to the fact that DSPLINK registers for signal handling by default and GStreamer also does the same hence a conflict. Ideally application should be handling the signals.Below thread discusses how to disable this - it is not straightforward config option while building - requires patching DSPLINK sources.
http://patchwork.kernel.org/patch/47281/
Pratheesh
