RE: Downgrading to 4.1.x/Seth
How in the hell can I downgrade to kernel 4.1.x once I have upgraded to 4.4.x? I am clueless right now and it feels icky. Anyway, I am messing w/ the Motor Bridge Cape again and I found someone that needs support.
  • I found that the MBC does not work w/ the BBB for some reason.
  • I am blaming it on the kernel version.- I could be wrong but…
  • I have tried every other avenue outside of using the BBG instead of the BBB (almost).
    So…
I have an incompatible, ill-fated backwards-compatible, Cape and BBB Rev. C and Rev. A5C. I have tried what I could for both boards but I had already upgraded to the newer kernel version(s). I tried the 4.9.x and 4.14.x kernels, respectively. No go!
P.S. If you have time and you care enough to give some info. on this matter, come on!
