Hello Group,
I have the BeagleBone black running “Linux beaglebone 4.4.36-ti-r72” kernel. I am trying to read CPU temperature and PowerVR SGX temperature.
I face below issues:
- The entries in
/sys/class/thermal/thermal_zone*
do not exits.
# ls -l /sys/class/thermal/thermal_zone*
ls: cannot access /sys/class/thermal/thermal_zone*: No such file or directory
total 0
- sensors-detect results in external abort
# sensors-detect
# sensors-detect revision 6209 (2014-01-14 22:51:58 +0100)
[253231.799042] Unhandled fault: external abort on non-linefetch (0x018) at 0xb6f96000
[253231.806811] pgd = db754000
[253231.809629] [b6f96000] *pgd=9c3c6831, *pte=000f0383, *ppte=000f0a33
[253231.843633] Unhandled fault: external abort on non-linefetch (0x018) at 0xb6f1e000
[253231.851404] pgd = dace4000
[253231.854221] [b6f1e000] *pgd=9b718831, *pte=000f0383, *ppte=000f0a33
[253231.887892] Unhandled fault: external abort on non-linefetch (0x018) at 0xb6f75000
[253231.895664] pgd = db640000
[253231.898482] [b6f75000] *pgd=9b6d7831, *pte=000f0383, *ppte=000f0a33
[253231.932160] Unhandled fault: external abort on non-linefetch (0x018) at 0xb6f92000
[253231.939933] pgd = db754000
[253231.942750] [b6f92000] *pgd=9b2a9831, *pte=000f0383, *ppte=000f0a33
[253231.975947] Unhandled fault: external abort on non-linefetch (0x018) at 0xb6f8c000
[253231.983721] pgd = dace4000
[253231.986539] [b6f8c000] *pgd=9b718831, *pte=000f0383, *ppte=000f0a33
[253232.020302] Unhandled fault: external abort on non-linefetch (0x018) at 0xb6fb0000
[253232.028074] pgd = db640000
[253232.030893] [b6fb0000] *pgd=9a86c831, *pte=000f0383, *ppte=000f0a33
[253232.064120] Unhandled fault: external abort on non-linefetch (0x018) at 0xb6f96000
[253232.071893] pgd = db754000
[253232.074711] [b6f96000] *pgd=9c3c6831, *pte=000f0383, *ppte=000f0a33
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Queries:
- Is it possible to read CPU temperature and SGX temperature in BBB? Is there any temperature sensor present on the AM3358 die or BBB board?
- Is there any LKM I can insert to get the temperature?
Thanks in advance.
