Hello all.
I'm working on my graduation final project and I need some help with the beagle. I need to read the GPIO ports through JAVA. Is there any java API to help me with that??? I'm running the UBUNTU 10.10 for OMAP3 processor.
Thanks in advance
Luis Gustavo
If you can access the filesystem from your VM check this out: http://www.avrfreaks.net/wiki/index.php/Documentation:Linux/GPIO
What you may need is called JNI. http://en.wikipedia.org/wiki/Java_Native_Interface there is a tutorial http://java.sun.com/developer/onlineTraining/Programming/JDCBook/jniexamp.html it isn't too bad to use and you could wrap all the special functions of your board.
