Charles Steinkuehler <charles@steinkuehler.net> [13-09-09 04:44]:
> Hi William,
> Thank you for your help!
> I did some investigations before and the "problem" I see is, that
> calling dtc will compile one .dts to a .dtb like gcc will produce a
> .o from a .c.
> But am335x-boneblack.dtb is more like an "executable" (it is not
> executed though): It is linked together from a lot of single .dts
> files.
You can easily work around this by turning the "compiled" dtb file into
a flat dts file with dtc, make your changes, then rebuild the dtb file.
The device tree files can be traslated back and forth between the
machine readable and human readable forms by the dtc program.
> Additionally and preferably I want to do it like or with a target of one
> of the makefiles in the Robert Nelson kernel tree to not to get
> hickups next time I update or rebuild the whole kernel tree...
To make it easy to track kernel changes, you should craft a patch with
your desired changes to the device tree and fold them into the patch.sh
script in a forked version of RCN's build scripts. It is then
reasonably straight-forward to merge in changes from upstream while
keeping your local modifications.
For an example, see my fork of RCN's kernel build script that adds
support for the Xenomai real-time patches. I have some extra code in
the git.sh script that pulls the Xenomai code, then I modify the local
kernel image at the end of the patch.sh script:
linux-dev/patch.sh at am33x-v3.8-bone26.1-xenomai · cdsteinkuehler/linux-dev · GitHub
Once you do this, you can "git fetch" changes from upstream and merge
them with your local changes easily (assuming you code reasonably well,
I suggest keeping your patches in their own procedure to keep the diffs
clean).
Hi Charles,
For the moment I try to figure out, what the makefile target is,
which build the regarding dtb file from the dts files.
Building patches and possibly provide them is a task, which I
will do, if I am sure, its working.
"Then rebuild the dtb file" is exactly which I want to do
with calling one of the dozen targets of the makefiles of
the kernel source.
Best regards,
mcc
