We are thinking of purchasing the BeagleBoard-xM. The Digi-Key
support page says that it support drivers for WiFi, but does not list
any recommended USB WiFi dongles. Can you please tell me a list of
dongles that this board supports?
Hans Troemel
Principal Electrical Engineer
nfuzion, Inc.
134 Main Street
LaGrange, GA 30240
Office: 678-884-0303 ext 212
Cell: 678-799-4173
Fax: 208-723-4220 hanst@nfuzion.com www.nfuzion.com
i tried the dlink nano usb dongle which was based on rtl8192 chipset. took me a while to modified the kernel for not loading firmware before getting it to function properly.
update: the rtl8192 dongle I use proved to be unstable after passing 500-600MB of data. I use it with WPA encryption on the connecting access point. The following was observed:
Loss of connection to the AP
Could not reconnect to AP (reboot required)
Seems that the staging driver on 2.6.32 has some more way to the stable kernel tree…
I am using an rtl8187 based dongle now with much better stability (passed almost 4GB of air traffic).
I am skeptical about performance though as dd from the mmc was giving around 2-3MB/s with the rtl8192 where with rtl8187 only gives 500-600kB. I will definitely test more to find out what’s wrong. Any thoughts welcome.
