Thank you for the reply.
I tried :
. /home/mum/.oe/environment-angstromv2012.05
bitbake linux-mainline-3.2.18 -c menuconfig
Then I actived SPI has shown in your link.
And I recompiled the Kernel :
bitbake -f -c compile linux-mainline-3.2.18
bitbake -f -c deploy linux-mainline-3.2.18
But just the uImage file was changed in the deploy directory.
The rootfs image qrchive is still the old one which has been created when I ran first time : MACHINE=beagleboard ./oebb.sh bitbake console-image
Maybe I should run the menuconfig before running MACHINE=beagleboard ./oebb.sh bitbake console-image
for the first time ?
There’s no need, normally, to change the root file system for enabling spi. SPI is only kernel-related and if you enable it at kernel level correctly, the /dev/spiX.X devices should come up automatically. So I think it’s correct the only your uImage was modified. Once the kernel is compiled, you should put the uImage in the Angstrom partition, more precisely in the /boot directory. This is the only change (adding the re-compiled kernel in the proper path) you should do in the rootfs.
Thank you !
No I can see the spidevs in /dev
I compiled spidev_test.c and I launched it :
$./spitest -D /dev/spidev4.0
And I had :
spi mode : 0
bits per word : 8
max speed : 500000 Hz (500 KHz) // Weird, because in board-omap3beagle.c I said that maxspeed was 48 MHz
After I had just a bunch of 00 in hexadecimal
but in all the example I read I should have some 0xFF
Do you have an idea ?
Hi Chris,
Yes I bridged them. I bridged McSPI4_SIMO (12) et McSPI4_SOMI (18).
The thinks which is weird is that I should have some 0xFF and not only 0x00 even if the bridge is not there.
What do you think about the code I added to board-omap3beagle.c ?
Hi Chris,
You will receive 0x00 if bridge is not there or there is an issue elsewhere. If everything setup/works correctly you will receive what you sent out McSPI4_SIMO. You can add a led to McSPI4_SIMO (if you don’t have a scope) and loop over the send in the test code to confirm you are able to send.
Looks ok but I’m unable to confirm as only have a beaglebone.Have you tried mode 3? This is what I’m currently using to talk to a slave device.
