recovering systemd services in beaglebone black
Hi friends when i deleted some service in systemd and put it back then it is showing bellow shown error please any one tell me how to recover hopefully i am waiting for replay
thank you
reserving fdt memory region: addr=88000000 size=6f000
Using Device Tree in place at 88000000, end 88071fff
Starting kernel …
[ 0.000858] clocksource_probe: no matching clocksources found
[ 2.378571] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.599432] omap_voltage_late_init: Voltage driver support not added
[ 2.606656] PM: Cannot get wkup_m3_ipc handle
[ 2.900716] bone_capemgr bone_capemgr: slot #0: No cape found
[ 2.931697] bone_capemgr bone_capemgr: slot #1: No cape found
[ 2.964344] bone_capemgr bone_capemgr: slot #2: No cape found
[ 2.996927] bone_capemgr bone_capemgr: slot #3: No cape found
[ 3.002752] bone_capemgr bone_capemgr: slot #4: override
[ 3.008134] bone_capemgr bone_capemgr: slot #4: ‘Override Board Name,00A0,Override Manuf,BB-BONE-4D5N-01’
[ 3.017901] bone_capemgr bone_capemgr: slot #5: override
[ 3.023282] bone_capemgr bone_capemgr: slot #5: ‘Override Board Name,00A0,Override Manuf,BB-BONE-4D5R-01’
[ 3.033018] bone_capemgr bone_capemgr: slot #6: override
[ 3.038395] bone_capemgr bone_capemgr: slot #6: ‘Override Board Name,00A0,Override Manuf,univ-nhdmi’
[ 3.419095] OF: changeset: add_property failed @/symbols/pruss
[ 3.459836] OF: Error applying changeset (-17)
[ 3.592180] bone_capemgr bone_capemgr: slot #6: Failed to create overlay
[ 3.620723] bone_capemgr bone_capemgr: loader: failed to load slot-6 univ-nhdmi:00A0 (prio 0)
[ 3.629604] bone_capemgr bone_capemgr: loader: failed to load slot-4 BB-BONE-4D5N-01:00A0 (prio 0)
[ 3.629871] bone_capemgr bone_capemgr: loader: failed to load slot-5 BB-BONE-4D5R-01:00A0 (prio 0)
rootfs: clean, 123149/233392 files, 751978/932864 blocks
[ 7.055070] systemd[1]: Cannot add dependency cron.service.save to multi-user.target, ignoring: Invalid argument
[FAILED] Failed to start Entropy daemon using the HAVEGE algorithm.
See ‘systemctl status haveged.service’ for details.
[ 7.178897] systemd-modules-load[233]: Failed to find module ‘lp’
[FAILED] Failed to start Network Time Synchronizatio[ 7.201961] systemd-modules-load[233]: Failed to find module ‘ppdev’
n.
[ 7.211842] systemd-modules-load[233]: Failed to find module ‘parport_pc’
See ‘systemctl status systemd-timesyncd.service’ for details.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target Slices.
[ OK ] Mounted /sys/kernel/debug.
[FAILED] Failed to start Load Kernel Modules.
See ‘systemctl status systemd-modules-load.service’ for details.
[DEPEND] Dependency failed for roboticscape.
[ OK ] Stopped Network Time Synchronization.
[FAILED] Failed to start Network Time Synchronization.
[ OK ] Reached target Local File Systems.
[ OK ] Reached target System Initialization.
[ OK ] Listening on GPS (Global Positioning System) Daemon Sockets.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Connection service…
[ OK ] Listening on node-red.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Cape Manager Service…
Starting LSB: BSD lpr/lpd line printer spooling system…
Starting LSB: Load kernel modules needed to enable cpufreq scaling…
Starting LSB: Start daemon at boot time…
Starting LSB: Start busybox udhcpd at boot time…
Starting Generic Board Startup…
[ OK ] Started Regular background program processing daemon.
[ OK ] Started CUPS Scheduler.
Starting Avahi mDNS/DNS-SD Stack…
[ OK ] Started Cape Manager Service.
[ OK ] Started LSB: BSD lpr/lpd line printer spooling system.
[ OK ] Started LSB: Start daemon at boot time.
[ OK ] Started LSB: Start busybox udhcpd at boot time.
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Connection service.
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server…
[ OK ] Reached target Network is Online.
Starting LSB: Advanced IEEE 802.11 management daemon…
[ OK ] Started Make remote CUPS printers available locally.
Starting LSB: SANE network scanner server…
[ OK ] Started LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[FAILED] Failed to start OpenBSD Secure Shell server.
See ‘systemctl status ssh.service’ for details.
[ OK ] Stopped OpenBSD Secure Shell server.
Starting LSB: set CPUFreq kernel parameters…
[ OK ] Started LSB: SANE network scanner server.
[ OK ] Started Generic Board Startup.
[FAILED] Failed to start Hostname Service.
See ‘systemctl status dbus-org.freedesktop.hostname1.service’ for details.
Starting WPA supplicant…
[ OK ] Started LSB: set CPUFreq kernel parameters.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
[ OK ] Started WPA supplicant.
[ 11.931462] systemd[1]: Failed to start OpenBSD Secure Shell server.
[ 12.407873] systemd[1]: Failed to start OpenBSD Secure Shell server.
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7.1 | VT102 | Online 5:33 | ttyUSB0
