I see up to 5.8 microseconds of latency when the PRU is reading from DDR
memory. Is it possible to reduce this? I tried changing registers that
looked promising for giving the PRU priority but they didn't have a
noticeable effect. This is running on a Beaglebone black using a PRU timer
to measure the maximum time a LBBO from DDR takes.while the ARM is busy.
The examples I found for doing DMA from the PRU were all for older kernels
and wouldn't work with Linux 3.8.13. Is there an example I missed that
works with this kernel?
I found the examples in ‘am335x_pru_package’ on GitHub very useful, and was able to get them working on a 3.8 kernel.
DDR access will have additional latency but 5.8us sounds high.
Is that for 1 LBBO instruction?
How are you timing this (which timer)?
What is the CPU doing during this time, if it is running 100% in a tight loop polling that same memory then CPU/PRU will be in contention, and that could cause excessive latency. Typically something like the pru interrupt is needed to let the cpu know that pru is done/ready etc.
I have used that. I don’t think there is a DMA example that works in there. I have everything working non DMA except the read latency is causing some difficulties in a few situations.
Yes that was for 1 LBBO. It times the LBBO, keeps the maximum and repeats.
The timer in the PRUSS enhanced capture unit.
I was running various commands to create load. The maximum happened with compiling my code. Reading files was close to the maximum. I was wanting to make sure it will work worst case. The ARM will be reading and writing a file and doing some other work in parallel with the PRU. Without carefully stripping down the system you also don’t know what else will decide to run. I am using the interrupt to signal the ARM that it needs to do more work for the PRU.
