Reference for Enabling GPIO Interrupt
I’m trying to work with Interrupts, firstly on GPIO.
Is there a reference code for enabling and working with interrupts on the AM335X? (BBB)
Thank you.
Hi again,
To be more focused, I learned that for setting an interrupt you need to simply set a priority if desired, and necessarily clear the desired INTC_MIRn bit.
However, when the Interrupt is generated, how do I define the Interrupt Handler Routine where I’d write the desired interrupt processing - e.g. turn on a LED when an interrupt is generated?
I mean, how do you know how to name the Interrupt Handler’s function?
Thank you.
Hi again,
Hi Matt,
I would suggest you to undertake some Linux Kernel training. Free Electrons have some excellent training available and this one is what you need.
http://free-electrons.com/doc/training/linux-kernel/
John
