I was able to setup NFS through USB net on beagleboard. Recently I purchased beagleboard-xm. With this new beagleboard-xm i am not able to setup NFS through USB otg. Pls let me know if there is any way of setting up NFS with begaleboard-xm using USB net or else if there is any kernel which supports ethernet as the kernel which i got along with the board doesnt have the driver for ethenet.
through USB otg.
The xm is a superset of the classic beagle so the same setup should work.
I understand it is the superset of bealgeboard. But the problem is once i connect usb cable to micro-usb slot, kernel panics. I tried using modprobe g_ether. After using modprobe kernel doesnt panic but when i set the ipaddress for the board and host, the host is not able to detect the usb net. I think the usb net is not getting up even after configuring the ipadress and using the command to getting it up.
