I have been trying how to find a way to do a relative branch (from the current instruction pointer) for a branch.
I have something like this:
.macro SETBIT
.mparam reg,bit,lab,lab2
QBBC lab, BYTE_VALUE,bit
SET r30, 14
QBA lab2
lab:
CLR r30,14
lab2:
What I would like to do is on the first QBBC, provide a relative label (so I don’t have to pass a unique name to the macro. The same for QBA lab2.
On a PIC one can do a $+#, where $ is the current instruction pointer, and the # is is the number of instructions to jump forward (or backward if negative). Is something like this possible?
You can read the program counter into a register, add an offset, and
then use a plain jump (to the register contents), but the quick-branch
instructions are already relative.
.macro SETBIT
SET r30, 14
QBA lab2
lab:
CLR r30,14
lab2:
I don't have to pass a unique name to the macro. The same for QBA lab2.
I'm not sure why you don't just put the labels inside the macro, where
they will be local in scope (see 5.3.3.1.1 "Defining a Macro" in the PRU
Reference Guide). If that doesn't solve your problem, perhaps a bit
more code would help to exhibit the particular issue you're trying to
overcome.
If I put the labels in the macro, then I will get a duplicate label (for the macro will be expanded out, and have multiple labels.
I have worked around this, by having the labels passed in, but would like to not have to do that.
Or is there something I am missing about scope on macros?
Hi Charles,
It's been too long and I can't remember if this is something I fixed in my assembler, but I use the following macro in my code without a problem:
136 : : .macro assert_bit_clear
137 : : ; ---------------
138 : : .mparam p1
139 : : .mparam p2
140 : : QBBC Ldone, p1, p2
141 : : HALT
142 : : Ldone:
143 : : .endm
144 :
If this doesn't work with the assembler you're using, have a look at my version here: https://github.com/modmaker/am335x_pru_package
-- Bas
