I am setting up remote debugging via gdbserver with Eclipse on my Beaglebone A6. I am getting the following error message:
Error in final launch sequence
Failed to execute MI command:
-target-select remote 192.168.0.15:2345
Error message from debugger back end:
Remote ‘g’ packet reply is too long:
On the Beagleboard I grabbed gdbserver using:
opkg install gdbserver
On my dev machine running Ubuntu 12.10 I pulled the multi architecture gdb using:
apt-get install gdb-multiarch
I’ve set remote debugging up successfully before on my Beagleboard C3 but I used gdb from a toolchain I got off narcissus.
I appears there is a difference between the arm-linux-gnueabi and arm-angstrom-linux-gnueabi toolchains. Can anyone enlighten me on the differences?
In the meantime I will see if using gdb from the angstrom generated toolchain solves my problem.
Andrew
