Replacing Cloud9 IDE with VS Code Server (bb-code-server)
Project cloud9 is dead but, it’s old (open-source) version still comes preinstalled with every beaglebone hardware. It needs to be changed and to do that we have shifted towards VS Code Server based soulution called bb-code-server. If your beaglebone image runs cloud9 and you want to use VS Code instead then this is for you.
Let’s quicly remove cloud9 and install bb-code-server on you BeagleBone hardware,
  • Update and upgrade
    sudo apt update
    sudo apt upgrade
  • Remove Cloud9
    sudo apt remove c9-core-installer
  • Install VS Code server (bb-code-server)
    sudo apt install bb-code-server
    sudo reboot
  • Start VS Code Server on http://192.168.7.2:3000
    sudo systemctl enable bb-code-server
    sudo systemctl start bb-code-server
  • Optional auto-start on boot
    sudo systemctl add-wants multi-user.target bb-code-server
Keep tinkering :wink:
Thanks @lorforlinux. I did install, compilation and execution are working. But facing issue with configuring debug. Any help on c/c++ debug configuration would be helpful. Thanks once again.
VSCode has a massive number of plugins, we also haven’t put together a perfect initial setup:
https://open-vsx.org/
Today, we only pre-install:
  • donjayamanne.githistory
  • formulahendry.code-runner
Edit, wonder if this would be uesful…
https://open-vsx.org/extension/franneck94/c-cpp-runner
Thanks, @RobertCNelson . I have installed C/C++ Runner but couldn’t compile using this extension. Since, the default launch.json not working. If there is example launch.json. that will help.
Current launch.json as follows,
  "version": "1.0.0",
  "configurations": [
      "name": "C/C++ Runner: Debug Session",
      "type": "cppdbg",
      "request": "launch",
      "args": [
      "stopAtEntry": false,
      "cwd": "/home/debian/example",
      "environment": [],
      "program": "/home/debian/example/build/Debug/outDebug",
      "internalConsoleOptions": "openOnSessionStart",
      "MIMode": "gdb",
      "miDebuggerPath": "gdb",
      "externalConsole": false,
      "setupCommands": [
          "description": "Enable pretty-printing for gdb",
          "text": "-enable-pretty-printing",
          "ignoreFailures": true
I’m new here but these instructions above worked perfectly for my BBB Industrial board as of Dec 1 2024. It has the 4GB eMMC with an 8GB SD card (which I don’t think VS Code is using). I was also able to install the Python language support extension and it appears to work. It does appear my eMMC drive is 96% full so I will likely need to uninstall some other items to make some room. root@beaglebone:/usr/local/mesh_services/meshagent/ngauge/bin# df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 218980 0 218980 0% /dev
tmpfs 49504 1556 47948 4% /run
/dev/mmcblk1p1 3607276 3263984 140336 96% /
tmpfs 247512 0 247512 0% /dev/shm
tmpfs 5120 0 5120 0% /run/lock
tmpfs 247512 0 247512 0% /sys/fs/cgroup
/dev/mmcblk0p1 7572344 34128 7133840 1% /usr/local/mesh_services/meshagent/ngauge
