Rev B5 USB issue
Hi Syed and Nazmul,
Now everything is working fine with th USB HUB. I was doing 1 mistake that I was connecting OTG port in the one of the 4 o/p port of USB Hub but actually it has to be connected in input port of the HUB.
What you have to do is buy 1 female to female connector and give OTG Cable Type A out to 1 Female connector side and other side connect it to the Input of 4 port Type A side of the HUB.
Vineet
This message (including any attachment) is confidential and may be legally privileged. Access to this message by anyone other than the intended recipient(s) listed above is unauthorized. If you are not the intended recipient you are hereby notified that any disclosure, copying, or distribution of the message, or any action taken or omission of action by you in reliance upon it, is prohibited and may be unlawful. Please immediately notify the sender by reply e-mail and permanently delete all copies of the message if you have received this message in error.
