Dirk
December 30, 2008, 10:35am
1
Anybody with a Beagle revision C2 board likes to test patch in attachment and report output?
It adds revision detection as described in
http://groups.google.com/group/beagleboard/msg/ceb2751f9dde458f
to U-Boot v1 git head as in Steve's git.
In case of success I would remove debug output and send updated patch.
Many thanks
Dirk
On my old Beagle I get
-- cut --
U-Boot 2009.01-rc1 (Dez 30 2008 - 11:24:54)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision: Ax/Bx
Debug (GPIO6 datain): 0x04801900
OMAP3 beagleboard.org #
-- cut --
u-boot-v1-beagle-revc2-detect.txt (4.76 KB)
There are currently no C2 boards in existence. All we have are Rev C1 which do have the resistors in them.
Dirk
December 30, 2008, 4:06pm
3
Well,
talked about Rev C2 I supposed C1 was just an other "try" and C2
would be the final one.
Ok, Jason already fixed it
http://www.beagleboard.org/gitweb/?p=u-boot-arm.git;a=blobdiff;f=board/omap3/beagle/beagle.c;h=7946e7c98b8fd959e838326db2c8d3d8bcb7c8de;hp=3f9939548159e2424603c55dd2e20b37f09af277;hb=3e11ac6c61d711adfa285cd48ae5a1666b0e7af5;hpb=3e27f686e8876bb2c25f46a12a4fd892a1c8becd
With "printf("Cx\n");" hopefully Koen won't complain that his C0 isn't
detected as rev Cx
Dirk
Dirk
December 30, 2008, 4:34pm
5
Gerald,
Jason Kridner wrote:
Well,
My Rev C1 is detected as a Rev Ax/Bx by this.
With Jason's Rev C1 GPIO module 6 data in register is
With this, my code assumes that GPIO_171 and GPIO_172 (GPIO6.11 and
GPIO6.12) are high and it reports Rev Ax/Bx.
Can you confirm that Jason's board has pull downs at GPIO6.11 and
GPIO6.12? And if yes, which mux config shall be used for GPIO6.11 and
GPIO6.12?
I used
MCSPI1_CLK: IEN | PTU | EN | M4 /* GPIO_171 */
MCSPI1_SIMO: IEN | PTU | EN | M4 /* GPIO_172 */
Dirk
Gerald,
Well,
GPIO6.12?
GPIO_172 is pulled down by R112, which is not populated on my board.
GPIO_171 is pulled down by R113, which I have not located on the board
yet.
The pulldowns may be too small. I have not been able to look at this myself, but you can short the resisotrs out to give it a hard low.
GPIO_171 is pulled down by R113, which I have not located on the board yet.
I did a quick probe of R113 (GPIO171) and it is sitting around 0.9V (resistor must have similar size as internal pull-up). R112 (not populated) (GPIO172) is sitting around 1.8V.
Aside: I need to figure out how to get Apple's Mail.app to switch easily between rich text and plain text.
Reminding me - What is preferred format for the mail group if any?
RTF/TXT/HTML?
Søren
Op 30 dec 2008, om 21:36 heeft Søren Steen Christensen het volgende geschreven:
RTF/TXT/HTML?
Plain text, preferably utf8. Also, bottom posting is preferred to top-posting.
regards,
Koen
Dirk
January 1, 2009, 6:43pm
11
Many thanks
Dirk
-- cut --
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
-- cut --
Patch update against recent git after Beagle GPIO clean up patch. No other changes, we still need to verify if this works on rev C (stronger pull downs?).
Dirk
Dirk
January 10, 2009, 7:46pm
12
Dirk Behme wrote:
Gerald,
Well,
GPIO6.12?
I used
With Beagle Rev C1D I get
Debug (GPIO6 datain): 0x04801100
I.e. GPIO_171 (GPIO6.11) is low, but GPIO_172 (GPIO6.12) is still
high. This is better than having both pins high like with Jason's
device above, but still not both pins low.
Will this be changed for the final shipping boards? I.e. will they
have both pins low? Or shall we detect Rev C by GPIO_171 (GPIO6.11)
low, only, and ignore GPIO_172 (GPIO6.12)?
Dirk
