I've noticed that if the core power domain gets powered off during
suspend, the MMC registers get reset. Which, among other things causes
the MMC host controller code to turn on VMMC1 even if no MMC card is
present.
I'm not sure if this is the right place to put this code. It also
doesn't work. If any of the __raw_readl commands execute, the board will
hang on a suspend attempt (assuming the core domain will be powered
off.) Strangely, the __raw_writel commands don't cause problems (other
than writing 0s to all the MMC registers.)
My platform is an OMAP3430 on a rev B7 Beagleboard. The patch is against
omap/pm.
present.
That would be because omap_mmc_suspend disables the interface clock.
The suspend method is a more logical place to save these registers,
but I'm not sure how to tell from the suspend method if the domain is
going to be turned off or not.
              Hello Russ,
> present.
Generally speaking, the device driver doesn't know this.  The powerdomain
target state decision may change after the device goes idle.  So the best
thing to do is to save context unconditionally before disabling clocks.
Another approach to saving device context that should work for most
registers is to save the register contents when the device registers are
written -- the "shadow register" approach.  That approach avoids
unnecessary latency in the device idle path and avoids some register
reads.
One other possible optimization.  In the event that the device context is
not lost, an unnecessary context restore can be avoided by using the
omap_pm_get_dev_context_loss_count() function.  (This is documented in
plat-omap/include/mach/omap-pm.h)  This function should be used by passing
a function pointer to the driver code in struct omap_mmc_platform_data,
called 'get_dev_context_loss_count' -- this should look something like the
example at the end of this E-mail.
Hope this helps,
- Paul
... In driver idle path, before clk_disable() ...
int loss_count;
if (pdata->get_dev_context_loss_count)
  loss_count = pdata->get_dev_context_loss_count();
... In driver resume path, after clk_enable() ...
int restore_needed = 1;
  if (pdata->get_dev_context_loss_count() == loss_count)
    restore_needed = 0;
if (restore_needed)
  /* restore device registers here */
