I have made substantial progress on my proposed "universal" device tree
overlay for the BeagleBone. The general idea is to enable all hardware
that is expected to be generally useful, and use the pinmux helper to
allow user-mode control of pin multiplexing (no writing kernel drivers
or editing device tree files required).
Attached is a first revision of such an overlay for the BeagleBone
Black. The eMMC, HDMI, and cape I2C EEPROM pins are left as-is, but all
other P8 and P9 pins are supported. After loading this overlay, all I/O
pins should be in their default reset state (GPIO input, with pull up or
pull down enabled depending on the pin). User code can then interact
with sysfs to configure the hardware as desired.
To change between functions, you echo the desired pinmux function to the
exported pinmux helper file. For example, to change P8 pin 13 to a PWM
output, as root:
echo pwm > /sys/devices/ocp.*/P8_13_pinmux.*/state
The supported values vary by pin, and you currently need to extract them
from the device tree file (documentation and a github repository are in
progress). In general, all pins support gpio, and most pins support one
or more of uart, pwm, pruin, pruout, spi, i2c, and can. In addition,
all pins support a "default" setting, which maps to the same as gpio
(ie: you can use default or gpio interchangeably).
Changing the GPIO mode is done the same as with any exported pin, you
access the files in /sys/class/gpio. For example, the following will
change P8 pin 13 to a GPIO output driving high, assuming you applied my
kernel patch to enable exporting gpio pins with changeable direction
(see previous e-mail):
echo high > /sys/class/gpio23/direction
Note that it is quite possible to "shoot yourself in the foot" with
regards to pin multiplexing, but this also allows things like only using
the Tx pin of a UART for serial communications, while using the Rx pin
for a GPIO or other special-purpose function. All without having to
create a custom device tree overlay, which is even more dangerous than
having to echo some values to the pinmux helper file!
Please review and comment, especially with regards to enabling the
hardware drivers. There was a *LOT* of cut-and-paste involved when
generating the overlay, so I won't be surprised if there's not a typo or
two lurking around. Also, I am not familiar enough with the SPI, I2C,
and PWM drivers to know if what I've got (generally extracted from the
device tree overlays shipped with the BeagleBone kernel source) are
suitable for generic use. Suggestions or pointers to good examples
outside the kernel tree would be welcome!
I'm also not completely happy with the naming conventions for the
various device tree nodes. Please comment if you have suggestions for
better names.
bone-universal-00A0.dts (52.5 KB)
