* Adds support for mt9v113 sensor by borrowing heavily from PSP 2.6.37 kernel patches
* Adapted to changes in v4l2 framework and ISP driver
Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com>
From: beagleboard@googlegroups.com [mailto:beagleboard@googlegroups.com]
On Behalf Of Joel A Fernandes
Sent: Wednesday, July 13, 2011 11:52 PM
To: beagleboard@googlegroups.com
Cc: Joel A Fernandes; Kridner, Jason; Javier Martin;
laurent.pinchart@ideasonboard.com; linux-media@vger.kernel.org; Kooi,
Koen; Prakash, Punya; Maupin, Chase; Kipisz, Steven; Aguirre, Sergio
Subject: [beagleboard] [RFC v1] mt9v113: VGA camera sensor driver and
support for BeagleBoard* Adds support for mt9v113 sensor by borrowing heavily from PSP 2.6.37
kernel patches
* Adapted to changes in v4l2 framework and ISP driverSigned-off-by: Joel A Fernandes <agnel.joel@gmail.com>
This patch will apply against the 2.6.39 kernel built from the OE-
development tree (Which is essentially
the v2.6.39 from the main tree with OE patches for BeagleBoard support and
a few other features)If you have the Leapord imaging camera board with this particular sensor,
I would apprecite it if anyone could
try this patch out and provide any feedback/test results.To get the complete tree which works on a BeagleBoard-xM with all the OE
patches and this patch,
you can clone: https://github.com/joelagnel/linux-omap-2.6/tree/oedev-
2.6.39-mt9v113It will compile and work on a BeagleBoard-xM with the defconfig at:
http://cgit.openembedded.org/cgit.cgi/openembedded/tree/recipes/linux/linu
x-omap-2.6.39/beagleboard/defconfigAlso you will need to apply my media-ctl patch (or clone the tree) to
setup the formats:
https://github.com/joelagnel/media-
ctl/commit/cdf24d1249ac1ff3cd6f70ad80c3b76ac28ba0d5Binaries for quick testing on a BeagleBoard-xM:
U-boot: http://utdallas.edu/~joel.fernandes/u-boot.bin
U-boot: http://utdallas.edu/~joel.fernandes/MLO
uEnv.txt: http://utdallas.edu/~joel.fernandes/uEnv.txt
media-ctl: http://utdallas.edu/~joel.fernandes/media-ctl
kernel: http://utdallas.edu/~joel.fernandes/uImagemedia-ctl/yavta commands you could use to get it to show a picture can be
found at:
http://utdallas.edu/~joel.fernandes/stream.shNote:
The BeagleBoard camera board file in this patch replaces the old one, so
this will take away support for the 5M
sensor (mt9p031), I hope this can be forgiven considering this is an
RFC :). I am working on a common board file
that will work for both sensors.
[Hiremath, Vaibhav] Joel,
I am bit surprised by this patch submission, first of all, the patch has been submitted without my knowledge. And I was not aware that you are targeting linux-media for this code-snippet.
This code needs lot of cleanup and changes to get to the level where we can submit it to the linux-media, and I think I clearly mentioned about known issues with this patch/driver in the commit itself. Please refer to the below commit -
I agree that we had some internal discussion on this and I was under assumption that this effort was only towards beagle openembedded and not for linux-media.
I also agree with the fact that, due to other critical issues I could not able to spend time on this and upstream it. But as I mentioned to you in one of private discussion, now we are working to get all this patches upstream and soon you will see patches coming in from my team.
Another important side note, you should always retain original authorship of the patches/commits/signoffs. It should always be in incremental order from baseline, which you are using.
Vaibhav
Sent: Wednesday, July 13, 2011 3:56 PM
Cc: Kridner, Jason; Javier Martin; laurent.pinchart@ideasonboard.com;
linux-media@vger.kernel.org; Kooi, Koen; Prakash, Punya; Maupin, Chase;
Subject: RE: [beagleboard] [RFC v1] mt9v113: VGA camera sensor driver
and support for BeagleBoard> From: beagleboard@googlegroups.com
2.6.37
> kernel patches
support and
sensor,
OE
2.6/tree/oedev-
> 2.6.39-mt9v113
inu
> setup the formats:
can be
> found at:
> Note:
so
[Hiremath, Vaibhav] Joel,I am bit surprised by this patch submission, first of all, the patch
This is an RFC, not a patch submission.
to the below commit -http://arago-project.org/git/projects/?p=linux-
omap3.git;a=commitdiff;h=c6174e0658b9aaa8f7a3ec9fe562619084d34f59I agree that we had some internal discussion on this and I was under
This is just an attempt to try to help clean it up. I think the patch for an older version of the kernel was already public. This isn't intended to be placed on the linux-media git tree. Many of the interested developers, however, may be on that list--and the code eventually needs to be made ready for inclusion on that git tree. Again, this is an RFC, not a patch submission.
I was not aware this was in conflict. That seems like exactly the reason we should be discussing this on the open external list--to avoid developers working redundantly on cleaning up patches for upstream.
Very good point. If this was not done properly, it seriously needs to be corrected. Thanks for that valuable review comment on what is essentially code you authored, by my understanding.
I do see your name in the copyright comments below. Where else is it missing?
Again, this was not submitted for inclusion into upstream trees--so I believe it is appropriate to get these corrections via the e-mail chain.
Hi Joel,
kernel patches * Adapted to changes in v4l2 framework and ISP driver
Here are a few comments about the code. I've left political issues aside on
purpose.
[snip]
diff --git a/drivers/media/video/Kconfig b/drivers/media/video/Kconfig
index 3a5bc57..7721aaa 100644
--- a/drivers/media/video/Kconfig
+++ b/drivers/media/video/Kconfig
@@ -351,6 +351,13 @@ config VIDEO_MT9V032
This is a Video4Linux2 sensor-level driver for the Micron
MT9V032 752x480 CMOS sensor.+config VIDEO_MT9V113
+ tristate "Aptina MT9V113 VGA CMOS IMAGE SENSOR"
No need to shout ![]()
+ depends on VIDEO_V4L2 && I2C
+ ---help---
+ This is a Video4Linux2 sensor-level driver for the Aptina MT9V113
+ image sensor.
config VIDEO_TCM825X
tristate "TCM825x camera sensor support"
depends on I2C && VIDEO_V4L2
[snip]
diff --git a/drivers/media/video/mt9v113.c b/drivers/media/video/mt9v113.c
new file mode 100644
index 0000000..96512a4
--- /dev/null
+++ b/drivers/media/video/mt9v113.c
@@ -0,0 +1,1027 @@
+ * drivers/media/video/mt9v113.c
+ * Based on TI TVP5146/47 decoder driver
+ * This package is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License version 2 as
+ * published by the Free Software Foundation.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
+#include <linux/i2c.h>
+#include <linux/delay.h>
+#include <linux/slab.h>
+#include <linux/v4l2-mediabus.h>
+#include <media/v4l2-chip-ident.h>
+#include <media/v4l2-device.h>
+#include <media/v4l2-subdev.h>
+#include <media/v4l2-ctrls.h>
+#include <media/mt9v113.h>
+#include "mt9v113_regs.h"
+/* Macro's */
+#define I2C_RETRY_COUNT (5)
+#define MT9V113_DEF_WIDTH 640
+#define MT9V113_DEF_HEIGHT 480
+/* Debug functions */
+static int debug = 1;
+module_param(debug, bool, 0644);
+MODULE_PARM_DESC(debug, "Debug level (0-1)");
+ * struct mt9v113 - sensor object
+ * @subdev: v4l2_subdev associated data
+ * @pad: media entity associated data
+ * @format: associated media bus format
+ * @rect: configured resolution/window
+ * @pdata: Board specific
+ * @ver: Chip version
+ * @power: Current power state (0: off, 1: on)
+struct mt9v113 {
+ struct v4l2_subdev subdev;
+ struct media_pad pad;
+ struct v4l2_mbus_framefmt format;
+ struct v4l2_rect rect;
+ struct v4l2_ctrl_handler ctrls;
+ const struct mt9v113_platform_data *pdata;
+ unsigned int ver;
+ bool power;
+#define to_mt9v113(sd) container_of(sd, struct mt9v113, subdev)
+ * struct mt9v113_fmt -
+ * @mbus_code: associated media bus code
+ * @fmt: format descriptor
+struct mt9v113_fmt {
+ unsigned int mbus_code;
+ struct v4l2_fmtdesc fmt;
The fmt field is never used, you can remove it.
+ * List of image formats supported by mt9v113
+ * Currently we are using 8 bit and 8x2 bit mode only, but can be
+ * extended to 10 bit mode.
+static const struct mt9v113_fmt mt9v113_fmt_list = {
+ .mbus_code = V4L2_MBUS_FMT_UYVY8_2X8,
+ .fmt = {
+ .index = 0,
+ .type = V4L2_BUF_TYPE_VIDEO_CAPTURE,
+ .flags = 0,
+ .description = "8-bit UYVY 4:2:2 Format",
+ .pixelformat = V4L2_PIX_FMT_UYVY,
+ .mbus_code = V4L2_MBUS_FMT_YUYV8_2X8,
+ .fmt = {
+ .index = 1,
+ .flags = 0,
+ .description = "8-bit YUYV 4:2:2 Format",
+ .pixelformat = V4L2_PIX_FMT_YUYV,
+ .mbus_code = V4L2_MBUS_FMT_RGB565_2X8_LE,
+ .fmt = {
+ .index = 2,
+ .flags = 0,
+ .description = "16-bit RGB565 format",
+ .pixelformat = V4L2_PIX_FMT_RGB565,
+/* MT9V113 register set for VGA mode */
+static struct mt9v113_reg mt9v113_vga_reg = {
+ {TOK_WRITE, 0x098C, 0x2739}, /* crop_X0_A */
+ {TOK_WRITE, 0x0990, 0x0000}, /* val: 0 */
+ {TOK_WRITE, 0x098C, 0x273B}, /* crop_X1_A */
+ {TOK_WRITE, 0x0990, 0x027F}, /* val: 639 */
+ {TOK_WRITE, 0x098C, 0x273D}, /* crop_Y0_A */
+ {TOK_WRITE, 0x098C, 0x273F}, /* crop_Y1_A */
+ {TOK_WRITE, 0x0990, 0x01DF}, /* val: 479 */
+ {TOK_WRITE, 0x098C, 0x2703}, /* output_width_A */
+ {TOK_WRITE, 0x0990, 0x0280}, /* val: 640 */
+ {TOK_WRITE, 0x098C, 0x2705}, /* out_height_A */
+ {TOK_WRITE, 0x0990, 0x01E0}, /* val: 480 */
+ {TOK_WRITE, 0x098C, 0xA103}, /* cmd */
+ {TOK_WRITE, 0x0990, 0x0005}, /* val: 5 - Refresh */
+ {TOK_DELAY, 0, 100},
+ {TOK_TERM, 0, 0},
I'm afraid this isn't an option. You need to compute those values dynamically
based on the selected crop rectangle and format.
+/* MT9V113 default register values */
+static struct mt9v113_reg mt9v113_reg_list = {
And this isn't an option either. Registers and their contents need to be
documented.
+ {TOK_WRITE, 0x0018, 0x4028},
+ {TOK_WRITE, 0x001A, 0x0011},
+ {TOK_WRITE, 0x001A, 0x0010},
+ {TOK_WRITE, 0x098C, 0x02F0},
+ {TOK_WRITE, 0x098C, 0x02F2},
+ {TOK_WRITE, 0x0990, 0x0210},
+ {TOK_WRITE, 0x098C, 0x02F4},
+ {TOK_WRITE, 0x0990, 0x001A},
+ {TOK_WRITE, 0x098C, 0x2145},
+ {TOK_WRITE, 0x0990, 0x02F4},
+ {TOK_WRITE, 0x098C, 0xA134},
+ {TOK_WRITE, 0x0990, 0x0001},
+ {TOK_WRITE, 0x31E0, 0x0001},
+ {TOK_WRITE, 0x001A, 0x0210},
+ {TOK_WRITE, 0x001E, 0x0777},
+ {TOK_WRITE, 0x0016, 0x42DF},
+ {TOK_WRITE, 0x0014, 0x2145},
+ {TOK_WRITE, 0x0010, 0x0431},
+ {TOK_WRITE, 0x0012, 0x0000},
+ {TOK_WRITE, 0x0014, 0x244B},
+ {TOK_WRITE, 0x0014, 0x304B},
+ {TOK_WRITE, 0x0014, 0xB04A},
+ {TOK_WRITE, 0x098C, 0xAB1F},
+ {TOK_WRITE, 0x0990, 0x00C7},
+ {TOK_WRITE, 0x098C, 0xAB31},
+ {TOK_WRITE, 0x0990, 0x001E},
+ {TOK_WRITE, 0x098C, 0x274F},
+ {TOK_WRITE, 0x0990, 0x0004},
+ {TOK_WRITE, 0x098C, 0x2741},
+ {TOK_WRITE, 0x098C, 0xAB20},
+ {TOK_WRITE, 0x0990, 0x0054},
+ {TOK_WRITE, 0x098C, 0xAB21},
+ {TOK_WRITE, 0x0990, 0x0046},
+ {TOK_WRITE, 0x098C, 0xAB22},
+ {TOK_WRITE, 0x0990, 0x0002},
+ {TOK_WRITE, 0x098C, 0xAB24},
+ {TOK_WRITE, 0x098C, 0x2B28},
+ {TOK_WRITE, 0x0990, 0x170C},
+ {TOK_WRITE, 0x098C, 0x2B2A},
+ {TOK_WRITE, 0x0990, 0x3E80},
+ {TOK_WRITE, 0x3210, 0x09A8},
+ {TOK_WRITE, 0x098C, 0x2306},
+ {TOK_WRITE, 0x0990, 0x0315},
+ {TOK_WRITE, 0x098C, 0x2308},
+ {TOK_WRITE, 0x0990, 0xFDDC},
+ {TOK_WRITE, 0x098C, 0x230A},
+ {TOK_WRITE, 0x0990, 0x003A},
+ {TOK_WRITE, 0x098C, 0x230C},
+ {TOK_WRITE, 0x0990, 0xFF58},
+ {TOK_WRITE, 0x098C, 0x230E},
+ {TOK_WRITE, 0x0990, 0x02B7},
+ {TOK_WRITE, 0x098C, 0x2310},
+ {TOK_WRITE, 0x0990, 0xFF31},
+ {TOK_WRITE, 0x098C, 0x2312},
+ {TOK_WRITE, 0x0990, 0xFF4C},
+ {TOK_WRITE, 0x098C, 0x2314},
+ {TOK_WRITE, 0x0990, 0xFE4C},
+ {TOK_WRITE, 0x098C, 0x2316},
+ {TOK_WRITE, 0x0990, 0x039E},
+ {TOK_WRITE, 0x098C, 0x2318},
+ {TOK_WRITE, 0x0990, 0x001C},
+ {TOK_WRITE, 0x098C, 0x231A},
+ {TOK_WRITE, 0x0990, 0x0039},
+ {TOK_WRITE, 0x098C, 0x231C},
+ {TOK_WRITE, 0x0990, 0x007F},
+ {TOK_WRITE, 0x098C, 0x231E},
+ {TOK_WRITE, 0x0990, 0xFF77},
+ {TOK_WRITE, 0x098C, 0x2320},
+ {TOK_WRITE, 0x0990, 0x000A},
+ {TOK_WRITE, 0x098C, 0x2322},
+ {TOK_WRITE, 0x0990, 0x0020},
+ {TOK_WRITE, 0x098C, 0x2324},
+ {TOK_WRITE, 0x0990, 0x001B},
+ {TOK_WRITE, 0x098C, 0x2326},
+ {TOK_WRITE, 0x0990, 0xFFC6},
+ {TOK_WRITE, 0x098C, 0x2328},
+ {TOK_WRITE, 0x0990, 0x0086},
+ {TOK_WRITE, 0x098C, 0x232A},
+ {TOK_WRITE, 0x0990, 0x00B5},
+ {TOK_WRITE, 0x098C, 0x232C},
+ {TOK_WRITE, 0x0990, 0xFEC3},
+ {TOK_WRITE, 0x098C, 0x232E},
+ {TOK_WRITE, 0x098C, 0x2330},
+ {TOK_WRITE, 0x0990, 0xFFEF},
+ {TOK_WRITE, 0x098C, 0xA348},
+ {TOK_WRITE, 0x0990, 0x0008},
+ {TOK_WRITE, 0x098C, 0xA349},
+ {TOK_WRITE, 0x098C, 0xA34A},
+ {TOK_WRITE, 0x0990, 0x0090},
+ {TOK_WRITE, 0x098C, 0xA34B},
+ {TOK_WRITE, 0x0990, 0x00FF},
+ {TOK_WRITE, 0x098C, 0xA34C},
+ {TOK_WRITE, 0x0990, 0x0075},
+ {TOK_WRITE, 0x098C, 0xA34D},
+ {TOK_WRITE, 0x0990, 0x00EF},
+ {TOK_WRITE, 0x098C, 0xA351},
+ {TOK_WRITE, 0x098C, 0xA352},
+ {TOK_WRITE, 0x098C, 0xA354},
+ {TOK_WRITE, 0x0990, 0x0043},
+ {TOK_WRITE, 0x098C, 0xA355},
+ {TOK_WRITE, 0x098C, 0xA35D},
+ {TOK_WRITE, 0x0990, 0x0078},
+ {TOK_WRITE, 0x098C, 0xA35E},
+ {TOK_WRITE, 0x098C, 0xA35F},
+ {TOK_WRITE, 0x0990, 0x007E},
+ {TOK_WRITE, 0x098C, 0xA360},
+ {TOK_WRITE, 0x0990, 0x0082},
+ {TOK_WRITE, 0x098C, 0x2361},
+ {TOK_WRITE, 0x0990, 0x0040},
+ {TOK_WRITE, 0x098C, 0xA363},
+ {TOK_WRITE, 0x0990, 0x00D2},
+ {TOK_WRITE, 0x098C, 0xA364},
+ {TOK_WRITE, 0x0990, 0x00F6},
+ {TOK_WRITE, 0x098C, 0xA302},
+ {TOK_WRITE, 0x098C, 0xA303},
+ {TOK_WRITE, 0x0990, 0x0024},
+ {TOK_WRITE, 0x0990, 0x0006},
+ {TOK_WRITE, 0x098C, 0x222D},
+ {TOK_WRITE, 0x0990, 0x0088},
+ {TOK_WRITE, 0x098C, 0xA408},
+ {TOK_WRITE, 0x098C, 0xA409},
+ {TOK_WRITE, 0x0990, 0x0023},
+ {TOK_WRITE, 0x098C, 0xA40A},
+ {TOK_WRITE, 0x0990, 0x0027},
+ {TOK_WRITE, 0x098C, 0xA40B},
+ {TOK_WRITE, 0x0990, 0x002A},
+ {TOK_WRITE, 0x098C, 0x2411},
+ {TOK_WRITE, 0x098C, 0x2413},
+ {TOK_WRITE, 0x0990, 0x00A4},
+ {TOK_WRITE, 0x098C, 0x2415},
+ {TOK_WRITE, 0x098C, 0x2417},
+ {TOK_WRITE, 0x098C, 0xA404},
+ {TOK_WRITE, 0x0990, 0x0010},
+ {TOK_WRITE, 0x098C, 0xA40D},
+ {TOK_WRITE, 0x098C, 0xA40E},
+ {TOK_WRITE, 0x0990, 0x0003},
+ /* test pattern all white*/
+ /* {TOK_WRITE, 0x098C, 0xA766},
+ {TOK_TERM, 0, 0},
+static int mt9v113_read_reg(struct i2c_client *client, unsigned short reg)
+ int err = 0;
+ struct i2c_msg msg[1];
+ unsigned char data[2];
+ unsigned short val = 0;
+ if (!client->adapter)
+ return -ENODEV;
+ msg->addr = client->addr;
+ msg->flags = 0;
+ msg->len = I2C_TWO_BYTE_TRANSFER;
+ msg->buf = data;
+ data[0] = (reg & I2C_TXRX_DATA_MASK_UPPER) >> I2C_TXRX_DATA_SHIFT;
+ data[1] = (reg & I2C_TXRX_DATA_MASK);
+ err = i2c_transfer(client->adapter, msg, 1);
+ if (err >= 0) {
+ msg->flags = I2C_M_RD;
+ msg->len = I2C_TWO_BYTE_TRANSFER; /* 2 byte read */
+ if (err >= 0) {
+ val = ((data[0] & I2C_TXRX_DATA_MASK) <<
+ I2C_TXRX_DATA_SHIFT) |
+ (data[1] & I2C_TXRX_DATA_MASK);
+ v4l_dbg(1, debug, client,
+ "mt9v113_read_reg reg=0x%x, val=0x%x\n", reg, val);
+ return (int)(0xffff & val);
+static int mt9v113_write_reg(struct i2c_client *client, unsigned short
reg, + unsigned short val)
+ int err = -EAGAIN; /* To enter below loop, err has to be negative */
+ int trycnt = 0;
+ unsigned char data[4];
+ "mt9v113_write_reg reg=0x%x, val=0x%x\n", reg, val);
+ return -ENODEV;
+ while ((err < 0) && (trycnt < I2C_RETRY_COUNT)) {
+ trycnt++;
+ msg->flags = 0;
+ msg->len = I2C_FOUR_BYTE_TRANSFER;
+ msg->buf = data;
+ I2C_TXRX_DATA_SHIFT;
+ data[2] = (val & I2C_TXRX_DATA_MASK_UPPER) >>
+ data[3] = (val & I2C_TXRX_DATA_MASK);
+ if (err < 0)
+ printk(KERN_INFO "\n I2C write failed");
+ return err;
+ * mt9v113_write_regs : Initializes a list of registers
+ * if token is TOK_TERM, then entire write operation terminates
+ * if token is TOK_DELAY, then a delay of 'val' msec is introduced
+ * if token is TOK_SKIP, then the register write is skipped
+ * if token is TOK_WRITE, then the register write is performed
+ * reglist - list of registers to be written
+ * Returns zero if successful, or non-zero otherwise.
+static int mt9v113_write_regs(struct i2c_client *client,
+ const struct mt9v113_reg reglist)
+ int err;
+ const struct mt9v113_reg *next = reglist;
+ for (; next->token != TOK_TERM; next++) {
+ if (next->token == TOK_DELAY) {
+ msleep(next->val);
+ continue;
+ if (next->token == TOK_SKIP)
+ continue;
+ err = mt9v113_write_reg(client, next->reg, next->val);
+ if (err < 0) {
+ v4l_err(client, "Write failed. Err[%d]\n", err);
+ return err;
+ return 0;
+ * Configure the mt9v113 with the current register settings
+static int mt9v113_def_config(struct v4l2_subdev *subdev)
+ struct i2c_client *client = v4l2_get_subdevdata(subdev);
+ /* common register initialization */
+ return mt9v113_write_regs(client, mt9v113_reg_list);
+ * Configure the MT9V113 to VGA mode
+static int mt9v113_vga_mode(struct v4l2_subdev *subdev)
+ return mt9v113_write_regs(client, mt9v113_vga_reg);
+ * Detect if an mt9v113 is present, and if so which revision.
+ * A device is considered to be detected if the chip ID (LSB and MSB)
+ * registers match the expected values.
+ * Any value of the rom version register is accepted.
+ * Returns ENODEV error number if no device is detected, or zero
+ * if a device is detected.
+static int mt9v113_detect(struct v4l2_subdev *subdev)
+ struct mt9v113 *decoder = to_mt9v113(subdev);
+ val = mt9v113_read_reg(client, REG_CHIP_ID);
+ v4l_dbg(1, debug, client, "chip id detected 0x%x\n", val);
+ if (MT9V113_CHIP_ID != val) {
+ /* We didn't read the values we expected, so this must not be
+ * MT9V113.
+ v4l_err(client, "chip id mismatch read 0x%x, expecting 0x%x\n",
+ val, MT9V113_CHIP_ID);
+ return -ENODEV;
+ decoder->ver = val;
+ v4l_info(client, "%s found at 0x%x (%s)\n", client->name,
+ client->addr << 1, client->adapter->name);
+ return 0;
+ * V4L2 subdev core operations
+ * mt9v113_g_chip_ident - get chip identifier
+static int mt9v113_g_chip_ident(struct v4l2_subdev *subdev,
+ struct v4l2_dbg_chip_ident *chip)
+ return v4l2_chip_ident_i2c_client(client, chip, V4L2_IDENT_MT9V113, 0);
This isn't needed when using the MC API.
+ * mt9v113_dev_init - sensor init, tries to detect the sensor
+ * @subdev: pointer to standard V4L2 subdev structure
+static int mt9v113_dev_init(struct v4l2_subdev *subdev)
This is the .registered operation handler, please rename it to
mt9v113_registered.
+ int rval;
+ rval = decoder->pdata->s_power(subdev, 1);
+ if (rval)
+ return rval;
+ rval = mt9v113_detect(subdev);
+ decoder->pdata->s_power(subdev, 0);
+ return rval;
+ * mt9v113_s_config - set the platform data for future use
+ * @irq:
+ * @platform_data: sensor platform_data
+static int mt9v113_s_config(struct v4l2_subdev *subdev, int irq,
+ void *platform_data)
+ int rval;
+ if (platform_data == NULL)
+ return -ENODEV;
+ decoder->pdata = platform_data;
+ rval = mt9v113_dev_init(subdev);
+ if (rval)
+ return rval;
+ return 0;
That's not used, you can remove it.
+ * mt9v113_s_power - Set power function
+ * @on: power state to which device is to be set
+ * Sets devices power state to requested state, if possible.
+static int mt9v113_s_power(struct v4l2_subdev *subdev, int on)
s/decoder/mt9v113/
+ int rval;
+ if (on) {
+ if (rval)
+ goto out;
+ rval = mt9v113_def_config(subdev);
+ if (rval) {
+ goto out;
+ rval = mt9v113_vga_mode(subdev);
+ if (rval) {
+ goto out;
+ } else {
+ rval = decoder->pdata->s_power(subdev, 0);
+ if (rval)
+ goto out;
You need to refcount power handling. See the mt9v032 driver.
+ decoder->power = on;
+out:
+ if (rval < 0)
+ v4l_err(client, "Unable to set target power state\n");
+ return rval;
+ * V4L2 subdev file operations
+static int mt9v113_open(struct v4l2_subdev *subdev, struct v4l2_subdev_fh
*fh) +{
+ struct v4l2_mbus_framefmt *format;
+ struct v4l2_rect *crop;
+ * Default configuration -
+ * Resolution: VGA
+ * Format: UYVY
+ * crop = window
+ crop = v4l2_subdev_get_try_crop(fh, 0);
+ crop->left = 0;
+ crop->top = 0;
+ crop->width = MT9V113_DEF_WIDTH;
+ crop->height = MT9V113_DEF_HEIGHT;
+ format = v4l2_subdev_get_try_format(fh, 0);
+ format->code = V4L2_MBUS_FMT_UYVY8_2X8;
+ format->width = MT9V113_DEF_WIDTH;
+ format->height = MT9V113_DEF_HEIGHT;
+ format->field = V4L2_FIELD_NONE;
+ format->colorspace = V4L2_COLORSPACE_JPEG;
+ return 0;
+ * V4L2 subdev video operations
+static int mt9v113_s_stream(struct v4l2_subdev *subdev, int streaming)
+ * FIXME: We should put here the specific reg setting to turn on
+ * streaming in sensor.
That would be a very good idea.
+ return 0;
+ * V4L2 subdev pad operations
+static int mt9v113_enum_mbus_code(struct v4l2_subdev *subdev,
+ struct v4l2_subdev_fh *fh,
+ struct v4l2_subdev_mbus_code_enum *code)
+ struct mt9v113 *mt9v113 = to_mt9v113(subdev);
+ if (code->index >= ARRAY_SIZE(mt9v113_fmt_list))
+ return -EINVAL;
+ code->code = mt9v113->format.code;
That will always return the active format code, it won't enumerate supported
options.
+ return 0;
+static int mt9v113_enum_frame_size(struct v4l2_subdev *subdev,
+ struct v4l2_subdev_frame_size_enum *fse)
+ int i;
+ /* Is requested media-bus format/pixelformat not found on sensor? */
+ for (i = 0; i < ARRAY_SIZE(mt9v113_fmt_list); i++) {
+ if (fse->code == mt9v113_fmt_list[i].mbus_code)
+ goto fmt_found;
break will do, as you check i after the loop.
+ if (i >= ARRAY_SIZE(mt9v113_fmt_list))
+ return -EINVAL;
+fmt_found:
+ * Currently only supports VGA resolution
+ fse->min_width = fse->max_width = MT9V113_DEF_WIDTH;
+ fse->min_height = fse->max_height = MT9V113_DEF_HEIGHT;
+ return 0;
+static int mt9v113_get_pad_format(struct v4l2_subdev *subdev,
+ struct v4l2_subdev_format *fmt)
+ fmt->format = mt9v113->format;
+ return 0;
+static int mt9v113_set_pad_format(struct v4l2_subdev *subdev,
+ int i;
+ if (fmt->format.code == mt9v113_fmt_list[i].mbus_code)
+ goto fmt_found;
+ return -EINVAL;
Don't return an error, pick a suitable default format instead.
+fmt_found:
+ * Only VGA resolution supported
+ fmt->format.width = MT9V113_DEF_WIDTH;
+ fmt->format.height = MT9V113_DEF_HEIGHT;
+ fmt->format.field = V4L2_FIELD_NONE;
+ fmt->format.colorspace = V4L2_COLORSPACE_JPEG;
+ mt9v113->format = fmt->format;
If only a single resolution is supported you don't need to store the whole
format structure in struct mt9v113. Storing the format code should be enough.
You need to handle active/try formats and store try formats in the file
handle. Same comment for crop rectangles.
+ return 0;
+static int mt9v113_get_crop(struct v4l2_subdev *subdev,
+ struct v4l2_subdev_fh *fh, struct v4l2_subdev_crop *crop)
+ crop->rect = mt9v113->rect;
+ return 0;
+static int mt9v113_set_crop(struct v4l2_subdev *subdev,
+ * Only VGA resolution/window is supported
+ rect.left = 0;
+ rect.top = 0;
+ rect.width = MT9V113_DEF_WIDTH;
+ rect.height = MT9V113_DEF_HEIGHT;
+ mt9v113->rect = rect;
No need to assign mt9v113->rect, it has already been initialized. crop->rect =
mt9v113->rect should do. And thinking about it, if you don't support modifying
the crop rectangle, there's no need to store its value in the mt9v113
structure.
+ crop->rect = rect;
Is cropping not supported by the sensor or just by the driver ?
+ return 0;
+static const struct v4l2_subdev_core_ops mt9v113_core_ops = {
+ .g_chip_ident = mt9v113_g_chip_ident,
+// .s_config = mt9v113_s_config,
No commented out code please.
+ .s_power = mt9v113_s_power,
+static const struct v4l2_subdev_internal_ops mt9v113_subdev_internal_ops =
{ + .open = mt9v113_open,
+ .registered = mt9v113_dev_init,
+static const struct v4l2_subdev_video_ops mt9v113_video_ops = {
+ .s_stream = mt9v113_s_stream,
+static const struct v4l2_subdev_pad_ops mt9v113_pad_ops = {
+ .enum_mbus_code = mt9v113_enum_mbus_code,
+ .enum_frame_size = mt9v113_enum_frame_size,
+ .get_fmt = mt9v113_get_pad_format,
+ .set_fmt = mt9v113_set_pad_format,
+ .get_crop = mt9v113_get_crop,
+ .set_crop = mt9v113_set_crop,
+static const struct v4l2_subdev_ops mt9v113_ops = {
+ .core = &mt9v113_core_ops,
+ .video = &mt9v113_video_ops,
+ .pad = &mt9v113_pad_ops,
--- + * V4L2 subdev control operations
+#define V4L2_CID_TEST_PATTERN (V4L2_CID_USER_BASE | 0x1001)
+ * mt9v113_s_ctrl - V4L2 decoder interface handler for VIDIOC_S_CTRL ioctl
+ * @s: pointer to standard V4L2 device structure
+ * @ctrl: pointer to v4l2_control structure
+ * If the requested control is supported, sets the control's current
+ * value in HW. Otherwise, returns -EINVAL if the control is not
supported. + */
+static int mt9v113_s_ctrl(struct v4l2_ctrl *ctrl)
+ container_of(ctrl->handler, struct mt9v113, ctrls);
+ struct i2c_client *client = v4l2_get_subdevdata(&mt9v113->subdev);
+ int err = -EINVAL, value;
+ if (ctrl == NULL)
+ return err;
I doubt this could happen.
+ value = (__s32) ctrl->val;
You can use ctrl->val directly in the rest of this function.
+ switch (ctrl->id) {
+ case V4L2_CID_BRIGHTNESS:
+ if (ctrl->val < 0 || ctrl->val > 255) {
+ v4l_err(client, "invalid brightness setting %d\n",
+ ctrl->val);
+ return -ERANGE;
This can't happen, it will be caught by the controls framework.
+ err = mt9v113_write_reg(client, REG_BRIGHTNESS, value);
+ if (err)
+ return err;
+ mt9v113_reg_list[REG_BRIGHTNESS].val = value;
What ? That's a no-go, you can't modify a driver-wide structure here.
+ break;
+ case V4L2_CID_CONTRAST:
Same comments as above for the next controls.
+ v4l_err(client, "invalid contrast setting %d\n",
+ ctrl->val);
+ return -ERANGE;
+ err = mt9v113_write_reg(client, REG_CONTRAST, value);
+ if (err)
+ return err;
+ mt9v113_reg_list[REG_CONTRAST].val = value;
+ break;
+ case V4L2_CID_SATURATION:
+ v4l_err(client, "invalid saturation setting %d\n",
+ ctrl->val);
+ return -ERANGE;
+ err = mt9v113_write_reg(client, REG_SATURATION, value);
+ if (err)
+ return err;
+ mt9v113_reg_list[REG_SATURATION].val = value;
+ break;
+ case V4L2_CID_HUE:
+ if (value == 180)
+ value = 0x7F;
+ else if (value == -180)
+ value = 0x80;
+ else if (value == 0)
+ value = 0;
That's really useful.
+ else {
+ v4l_err(client, "invalid hue setting %d\n",
+ ctrl->val);
+ return -ERANGE;
+ err = mt9v113_write_reg(client, REG_HUE, value);
+ if (err)
+ return err;
+ mt9v113_reg_list[REG_HUE].val = value;
+ break;
+ case V4L2_CID_AUTOGAIN:
+ if (value == 1)
+ value = 0x0F;
+ value = 0x0C;
+ else {
+ v4l_err(client, "invalid auto gain setting %d\n",
+ ctrl->val);
+ return -ERANGE;
+ err = mt9v113_write_reg(client, REG_AFE_GAIN_CTRL, value);
+ if (err)
+ return err;
+ mt9v113_reg_list[REG_AFE_GAIN_CTRL].val = value;
+ break;
+ case V4L2_CID_TEST_PATTERN:
+ switch (ctrl->val) {
+ case 0:
+ break;
+ /* FIXME Add proper Test pattern code here */
Please add proper test pattern code here ![]()
+ return mt9v113_write_reg(client, 0, 0);
+ default:
+ v4l_err(client, "invalid control id %d\n", ctrl->id);
This can't happen, it will be caught by the control framework.
+ return err;
+ "Set Control: ID - %d - %d", ctrl->id, ctrl->val);
+ return err;
+static struct v4l2_ctrl_ops mt9v113_ctrl_ops = {
+ .s_ctrl = mt9v113_s_ctrl,
+static const struct v4l2_ctrl_config mt9v113_ctrls = {
+ .ops = &mt9v113_ctrl_ops,
+ .id = V4L2_CID_TEST_PATTERN,
+ .type = V4L2_CTRL_TYPE_INTEGER,
+ .name = "Test pattern",
+ .min = 0,
+ .max = 1023,
+ .step = 1,
+ .def = 0,
+ .flags = 0,
Maybe it's time to standardize a test pattern control ?
+ * mt9v113_probe - sensor driver i2c probe handler
+ * @client: i2c driver client device structure
+ * Register sensor as an i2c client device and V4L2
+ * sub-device.
+static int mt9v113_probe(struct i2c_client *client,
+ const struct i2c_device_id *id)
+ struct mt9v113 *mt9v113;
+ int i, ret;
+ /* Check if the adapter supports the needed features */
+ if (!i2c_check_functionality(client->adapter,
+ I2C_FUNC_SMBUS_BYTE_DATA)) {
+ v4l_err(client, "mt9v113: I2C Adapter doesn't support" \
+ " I2C_FUNC_SMBUS_WORD\n");
+ return -EIO;
+ if (!client->dev.platform_data) {
+ v4l_err(client, "No platform data!!\n");
+ return -ENODEV;
+ mt9v113 = kzalloc(sizeof(*mt9v113), GFP_KERNEL);
+ if (mt9v113 == NULL) {
+ v4l_err(client, "Could not able to alocate memory!!\n");
+ return -ENOMEM;
+ mt9v113->pdata = client->dev.platform_data;
+ * Initialize and register available controls
+ v4l2_ctrl_handler_init(&mt9v113->ctrls, ARRAY_SIZE(mt9v113_ctrls) + 4);
+ v4l2_ctrl_new_std(&mt9v113->ctrls, &mt9v113_ctrl_ops,
+ V4L2_CID_AUTOGAIN, 0, 1, 1, 1);
Your s_ctrl handler supports more than this.
+ for (i = 0; i < ARRAY_SIZE(mt9v113_ctrls); ++i)
+ v4l2_ctrl_new_custom(&mt9v113->ctrls, &mt9v113_ctrls[i], NULL);
+ mt9v113->subdev.ctrl_handler = &mt9v113->ctrls;
+ if (mt9v113->ctrls.error)
+ v4l_info(client, "%s: error while initialization control %d\n",
+ __func__, mt9v113->ctrls.error);
+ * Resolution: VGA
+ * Format: UYVY
+ * crop = window
+ mt9v113->rect.left = 0;
+ mt9v113->rect.top = 0;
+ mt9v113->rect.width = MT9V113_DEF_WIDTH;
+ mt9v113->rect.height = MT9V113_DEF_HEIGHT;
I don't have the MT9V113 datasheet, but doesn't the sensor have black
lines/columns around its active area ? Does the default active area really
start at (0,0) ?
+ mt9v113->format.code = V4L2_MBUS_FMT_UYVY8_2X8;
+ mt9v113->format.width = MT9V113_DEF_WIDTH;
+ mt9v113->format.height = MT9V113_DEF_HEIGHT;
+ mt9v113->format.field = V4L2_FIELD_NONE;
+ mt9v113->format.colorspace = V4L2_COLORSPACE_JPEG;
+ * Register as a subdev
+ v4l2_i2c_subdev_init(&mt9v113->subdev, client, &mt9v113_ops);
+ mt9v113->subdev.internal_ops = &mt9v113_subdev_internal_ops;
+ mt9v113->subdev.flags |= V4L2_SUBDEV_FL_HAS_DEVNODE;
+ * Register as media entity
+ mt9v113->pad.flags = MEDIA_PAD_FL_SOURCE;
+ ret = media_entity_init(&mt9v113->subdev.entity, 1, &mt9v113->pad, 0);
+ if (ret < 0) {
+ v4l_err(client, "failed to register as a media entity\n");
+ kfree(mt9v113);
+ return ret;
+ * mt9v113_remove - Sensor driver i2c remove handler
+ * Unregister sensor as an i2c client device and V4L2
+ * sub-device.
+static int __exit mt9v113_remove(struct i2c_client *client)
+ struct v4l2_subdev *subdev = i2c_get_clientdata(client);
+ v4l2_device_unregister_subdev(subdev);
+ media_entity_cleanup(&subdev->entity);
+ kfree(mt9v113);
+ return 0;
+static const struct i2c_device_id mt9v113_id = {
+ { MT9V113_MODULE_NAME, 0 },
+MODULE_DEVICE_TABLE(i2c, mt9v113_id);
+static struct i2c_driver mt9v113_i2c_driver = {
+ .driver = {
+ .name = MT9V113_MODULE_NAME,
+ .owner = THIS_MODULE,
+ .probe = mt9v113_probe,
+ .remove = __exit_p(mt9v113_remove),
+ .id_table = mt9v113_id,
+static int __init mt9v113_init(void)
+ return i2c_add_driver(&mt9v113_i2c_driver);
+static void __exit mt9v113_cleanup(void)
+ i2c_del_driver(&mt9v113_i2c_driver);
+module_init(mt9v113_init);
+module_exit(mt9v113_cleanup);
+MODULE_AUTHOR("Texas Instruments");
+MODULE_DESCRIPTION("MT9V113 camera sensor driver");
+MODULE_LICENSE("GPL");
diff --git a/drivers/media/video/mt9v113_regs.h
b/drivers/media/video/mt9v113_regs.h new file mode 100644
index 0000000..64b065f
--- /dev/null
+++ b/drivers/media/video/mt9v113_regs.h
@@ -0,0 +1,294 @@
+ * drivers/media/video/mt9v113_regs.h
+ * Copyright (C) 2008 Texas Instruments Inc
+ * Author: Vaibhav Hiremath <hvaibhav@ti.com>
+ * Contributors:
+ * Sivaraj R <sivaraj@ti.com>
+ * Brijesh R Jadav <brijesh.j@ti.com>
+ * Hardik Shah <hardik.shah@ti.com>
+ * Manjunath Hadli <mrh@ti.com>
+ * Karicheri Muralidharan <m-karicheri2@ti.com>
+#ifndef _MT9V113_REGS_H
+#define _MT9V113_REGS_H
+ * MT9V113 registers
+#define REG_CHIP_ID (0x00)
There's no need to put hex constants inside brackets.
+#define REG_INPUT_SEL (0x00)
+#define REG_AFE_GAIN_CTRL (0x01)
+#define REG_VIDEO_STD (0x02)
+#define REG_OPERATION_MODE (0x03)
+#define REG_AUTOSWITCH_MASK (0x04)
+#define REG_COLOR_KILLER (0x05)
+#define REG_LUMA_CONTROL1 (0x06)
+#define REG_LUMA_CONTROL2 (0x07)
+#define REG_LUMA_CONTROL3 (0x08)
+#define REG_BRIGHTNESS (0x09)
Lowercase hex constants please.
+#define REG_CONTRAST (0x0A)
+#define REG_SATURATION (0x0B)
+#define REG_HUE (0x0C)
+#define REG_CHROMA_CONTROL1 (0x0D)
+#define REG_CHROMA_CONTROL2 (0x0E)
+/* 0x0F Reserved */
+#define REG_COMP_PR_SATURATION (0x10)
+#define REG_COMP_Y_CONTRAST (0x11)
+#define REG_COMP_PB_SATURATION (0x12)
+/* 0x13 Reserved */
+#define REG_COMP_Y_BRIGHTNESS (0x14)
+/* 0x15 Reserved */
+#define REG_AVID_START_PIXEL_LSB (0x16)
+#define REG_AVID_START_PIXEL_MSB (0x17)
+#define REG_AVID_STOP_PIXEL_LSB (0x18)
+#define REG_AVID_STOP_PIXEL_MSB (0x19)
+#define REG_HSYNC_START_PIXEL_LSB (0x1A)
+#define REG_HSYNC_START_PIXEL_MSB (0x1B)
+#define REG_HSYNC_STOP_PIXEL_LSB (0x1C)
+#define REG_HSYNC_STOP_PIXEL_MSB (0x1D)
+#define REG_VSYNC_START_LINE_LSB (0x1E)
+#define REG_VSYNC_START_LINE_MSB (0x1F)
+#define REG_VSYNC_STOP_LINE_LSB (0x20)
+#define REG_VSYNC_STOP_LINE_MSB (0x21)
+#define REG_VBLK_START_LINE_LSB (0x22)
+#define REG_VBLK_START_LINE_MSB (0x23)
+#define REG_VBLK_STOP_LINE_LSB (0x24)
+#define REG_VBLK_STOP_LINE_MSB (0x25)
+/* 0x26 - 0x27 Reserved */
+#define REG_FAST_SWTICH_CONTROL (0x28)
+/* 0x29 Reserved */
+#define REG_FAST_SWTICH_SCART_DELAY (0x2A)
+/* 0x2B Reserved */
+#define REG_SCART_DELAY (0x2C)
+#define REG_CTI_DELAY (0x2D)
+#define REG_CTI_CONTROL (0x2E)
+/* 0x2F - 0x31 Reserved */
+#define REG_SYNC_CONTROL (0x32)
+#define REG_OUTPUT_FORMATTER1 (0x33)
+#define REG_OUTPUT_FORMATTER2 (0x34)
+#define REG_OUTPUT_FORMATTER3 (0x35)
+#define REG_OUTPUT_FORMATTER4 (0x36)
+#define REG_OUTPUT_FORMATTER5 (0x37)
+#define REG_OUTPUT_FORMATTER6 (0x38)
+#define REG_CLEAR_LOST_LOCK (0x39)
+#define REG_STATUS1 (0x3A)
+#define REG_STATUS2 (0x3B)
+#define REG_AGC_GAIN_STATUS_LSB (0x3C)
+#define REG_AGC_GAIN_STATUS_MSB (0x3D)
+/* 0x3E Reserved */
+#define REG_VIDEO_STD_STATUS (0x3F)
+#define REG_GPIO_INPUT1 (0x40)
+#define REG_GPIO_INPUT2 (0x41)
+/* 0x42 - 0x45 Reserved */
+#define REG_AFE_COARSE_GAIN_CH1 (0x46)
+#define REG_AFE_COARSE_GAIN_CH2 (0x47)
+#define REG_AFE_COARSE_GAIN_CH3 (0x48)
+#define REG_AFE_COARSE_GAIN_CH4 (0x49)
+#define REG_AFE_FINE_GAIN_PB_B_LSB (0x4A)
+#define REG_AFE_FINE_GAIN_PB_B_MSB (0x4B)
+#define REG_AFE_FINE_GAIN_Y_G_CHROMA_LSB (0x4C)
+#define REG_AFE_FINE_GAIN_Y_G_CHROMA_MSB (0x4D)
+#define REG_AFE_FINE_GAIN_PR_R_LSB (0x4E)
+#define REG_AFE_FINE_GAIN_PR_R_MSB (0x4F)
+#define REG_AFE_FINE_GAIN_CVBS_LUMA_LSB (0x50)
+#define REG_AFE_FINE_GAIN_CVBS_LUMA_MSB (0x51)
+/* 0x52 - 0x68 Reserved */
+#define REG_FBIT_VBIT_CONTROL1 (0x69)
+/* 0x6A - 0x6B Reserved */
+#define REG_BACKEND_AGC_CONTROL (0x6C)
+/* 0x6D - 0x6E Reserved */
+#define REG_AGC_DECREMENT_SPEED_CONTROL (0x6F)
+#define REG_ROM_VERSION (0x70)
+/* 0x71 - 0x73 Reserved */
+#define REG_AGC_WHITE_PEAK_PROCESSING (0x74)
+#define REG_FBIT_VBIT_CONTROL2 (0x75)
+#define REG_VCR_TRICK_MODE_CONTROL (0x76)
+#define REG_HORIZONTAL_SHAKE_INCREMENT (0x77)
+#define REG_AGC_INCREMENT_SPEED (0x78)
+#define REG_AGC_INCREMENT_DELAY (0x79)
+/* 0x7A - 0x7F Reserved */
+#define REG_CHIP_ID_MSB (0x80)
+#define REG_CHIP_ID_LSB (0x81)
+/* 0x82 Reserved */
+#define REG_CPLL_SPEED_CONTROL (0x83)
+/* 0x84 - 0x96 Reserved */
+#define REG_STATUS_REQUEST (0x97)
+/* 0x98 - 0x99 Reserved */
+#define REG_VERTICAL_LINE_COUNT_LSB (0x9A)
+#define REG_VERTICAL_LINE_COUNT_MSB (0x9B)
+/* 0x9C - 0x9D Reserved */
+#define REG_AGC_DECREMENT_DELAY (0x9E)
+/* 0x9F - 0xB0 Reserved */
+#define REG_VDP_TTX_FILTER_1_MASK1 (0xB1)
+#define REG_VDP_TTX_FILTER_1_MASK2 (0xB2)
+#define REG_VDP_TTX_FILTER_1_MASK3 (0xB3)
+#define REG_VDP_TTX_FILTER_1_MASK4 (0xB4)
+#define REG_VDP_TTX_FILTER_1_MASK5 (0xB5)
+#define REG_VDP_TTX_FILTER_2_MASK1 (0xB6)
+#define REG_VDP_TTX_FILTER_2_MASK2 (0xB7)
+#define REG_VDP_TTX_FILTER_2_MASK3 (0xB8)
+#define REG_VDP_TTX_FILTER_2_MASK4 (0xB9)
+#define REG_VDP_TTX_FILTER_2_MASK5 (0xBA)
+#define REG_VDP_TTX_FILTER_CONTROL (0xBB)
+#define REG_VDP_FIFO_WORD_COUNT (0xBC)
+#define REG_VDP_FIFO_INTERRUPT_THRLD (0xBD)
+/* 0xBE Reserved */
+#define REG_VDP_FIFO_RESET (0xBF)
+#define REG_VDP_FIFO_OUTPUT_CONTROL (0xC0)
+#define REG_VDP_LINE_NUMBER_INTERRUPT (0xC1)
+#define REG_VDP_PIXEL_ALIGNMENT_LSB (0xC2)
+#define REG_VDP_PIXEL_ALIGNMENT_MSB (0xC3)
+/* 0xC4 - 0xD5 Reserved */
+#define REG_VDP_LINE_START (0xD6)
+#define REG_VDP_LINE_STOP (0xD7)
+#define REG_VDP_GLOBAL_LINE_MODE (0xD8)
+#define REG_VDP_FULL_FIELD_ENABLE (0xD9)
+#define REG_VDP_FULL_FIELD_MODE (0xDA)
+/* 0xDB - 0xDF Reserved */
+#define REG_VBUS_DATA_ACCESS_NO_VBUS_ADDR_INCR (0xE0)
+#define REG_VBUS_DATA_ACCESS_VBUS_ADDR_INCR (0xE1)
+#define REG_FIFO_READ_DATA (0xE2)
+/* 0xE3 - 0xE7 Reserved */
+#define REG_VBUS_ADDRESS_ACCESS1 (0xE8)
+#define REG_VBUS_ADDRESS_ACCESS2 (0xE9)
+#define REG_VBUS_ADDRESS_ACCESS3 (0xEA)
+/* 0xEB - 0xEF Reserved */
+#define REG_INTERRUPT_RAW_STATUS0 (0xF0)
+#define REG_INTERRUPT_RAW_STATUS1 (0xF1)
+#define REG_INTERRUPT_STATUS0 (0xF2)
+#define REG_INTERRUPT_STATUS1 (0xF3)
+#define REG_INTERRUPT_MASK0 (0xF4)
+#define REG_INTERRUPT_MASK1 (0xF5)
+#define REG_INTERRUPT_CLEAR0 (0xF6)
+#define REG_INTERRUPT_CLEAR1 (0xF7)
+/* 0xF8 - 0xFF Reserved */
+/* The ID values we are looking for */
+#define MT9V113_CHIP_ID_MSB (0x51)
+#define MT9V113_IMAGE_STD_VGA (0x01)
+#define MT9V113_IMAGE_STD_QVGA (0x02)
+#define MT9V113_IMAGE_STD_INVALID (0xFF)
+ * Status bit
+#define STATUS_TV_VCR_BIT (1<<0)
+#define STATUS_HORZ_SYNC_LOCK_BIT (1<<1)
+#define STATUS_VIRT_SYNC_LOCK_BIT (1<<2)
+#define STATUS_CLR_SUBCAR_LOCK_BIT (1<<3)
+#define STATUS_LOST_LOCK_DETECT_BIT (1<<4)
+#define STATUS_FEILD_RATE_BIT (1<<5)
+#define STATUS_LINE_ALTERNATING_BIT (1<<6)
+#define STATUS_PEAK_WHITE_DETECT_BIT (1<<7)
+/* Tokens for register write */
+#define TOK_WRITE (0) /* token for write
operation */ +#define TOK_TERM (1) /*
terminating token */ +#define TOK_DELAY (2) /*
delay token for reg list */ +#define TOK_SKIP (3)
/* token to skip a register */ +/**
+ * struct mt9v113_reg - Structure for TVP5146/47 register initialization
values + * @token - Token: TOK_WRITE, TOK_TERM etc..
+ * @reg - Register offset
+ * @val - Register Value for TOK_WRITE or delay in ms for TOK_DELAY
+struct mt9v113_reg {
+ unsigned short token;
+ unsigned short reg;
+ unsigned short val;
+ * struct mt9v113_init_seq - Structure for TVP5146/47/46M2/47M1 power up
+ * Sequence.
+ * @ no_regs - Number of registers to write for power up sequence.
+ * @ init_reg_seq - Array of registers and respective value to write.
+struct mt9v113_init_seq {
+ unsigned int no_regs;
+ const struct mt9v113_reg *init_reg_seq;
+#define MT9V113_CHIP_ID (0x2280)
+#endif /* ifndef _MT9V113_REGS_H */
diff --git a/drivers/media/video/omap3isp/ispccdc.c
b/drivers/media/video/omap3isp/ispccdc.c index 39d501b..cc62f66 100644
--- a/drivers/media/video/omap3isp/ispccdc.c
+++ b/drivers/media/video/omap3isp/ispccdc.c
@@ -57,6 +57,8 @@ static const unsigned int ccdc_fmts = {
V4L2_MBUS_FMT_SRGGB12_1X12,
V4L2_MBUS_FMT_SBGGR12_1X12,
V4L2_MBUS_FMT_SGBRG12_1X12,
+ V4L2_MBUS_FMT_UYVY8_2X8,
+ V4L2_MBUS_FMT_YUYV8_2X8,
OMAP3 ISP changes should be split into a separate patch.
@@ -1176,7 +1178,13 @@ static void ccdc_configure(struct isp_ccdc_device
*ccdc) else
syn_mode &= ~ISPCCDC_SYN_MODE_PACK8;- isp_reg_writel(isp, syn_mode, OMAP3_ISP_IOMEM_CCDC, ISPCCDC_SYN_MODE);
+ if ((format->code == V4L2_MBUS_FMT_YUYV8_2X8) ||
+ (format->code == V4L2_MBUS_FMT_UYVY8_2X8))
+ syn_mode |= ISPCCDC_SYN_MODE_INPMOD_YCBCR16;
+ else
+ syn_mode &= ~ISPCCDC_SYN_MODE_INPMOD_MASK;
+ isp_reg_writel(isp, syn_mode, OMAP3_ISP_IOMEM_CCDC,
ISPCCDC_SYN_MODE);
You need more than this. When the CCDC receives YUV data it can't forward it
to the preview engine, but can forward it to the resizer. This should be
supported.
/* Mosaic filter */
switch (format->code) {
diff --git a/drivers/media/video/omap3isp/ispvideo.c
b/drivers/media/video/omap3isp/ispvideo.c index 9cd8f1a..b47fb6e 100644
--- a/drivers/media/video/omap3isp/ispvideo.c
+++ b/drivers/media/video/omap3isp/ispvideo.c
@@ -97,9 +97,12 @@ static struct isp_format_info formats = {
{ V4L2_MBUS_FMT_UYVY8_1X16, V4L2_MBUS_FMT_UYVY8_1X16,
V4L2_MBUS_FMT_UYVY8_1X16, 0,
V4L2_PIX_FMT_UYVY, 16, },
- { V4L2_MBUS_FMT_YUYV8_1X16, V4L2_MBUS_FMT_YUYV8_1X16,
- V4L2_MBUS_FMT_YUYV8_1X16, 0,
Why do you remove the V4L2_MBUS_FMT_YUYV8_1X16 entry ?
+ { V4L2_MBUS_FMT_YUYV8_2X8, V4L2_MBUS_FMT_YUYV8_2X8,
+ V4L2_MBUS_FMT_YUYV8_2X8, 0,
V4L2_PIX_FMT_YUYV, 16, },
+ { V4L2_MBUS_FMT_UYVY8_2X8, V4L2_MBUS_FMT_UYVY8_2X8,
+ V4L2_MBUS_FMT_UYVY8_2X8, 0,
+ V4L2_PIX_FMT_UYVY, 16, },
};const struct isp_format_info *
diff --git a/include/media/mt9v113.h b/include/media/mt9v113.h
index 0000000..0d37f17
--- /dev/null
+++ b/include/media/mt9v113.h
@@ -0,0 +1,70 @@
+ * drivers/media/video/mt9v113.h
+ * Contributors:
+#ifndef _MT9V113_H
+#define _MT9V113_H
+#include <media/media-entity.h>
+ * Other macros
+#define MT9V113_MODULE_NAME "mt9v113"
+/* Number of pixels and number of lines per frame for different standards
*/ +#define VGA_NUM_ACTIVE_PIXELS 640
+#define VGA_NUM_ACTIVE_LINES 480
+#define QVGA_NUM_ACTIVE_PIXELS 320
+#define QVGA_NUM_ACTIVE_LINES 240
+struct mt9v113_platform_data {
+ int (*s_power)(struct v4l2_subdev *subdev, int on);
+ int (*set_xclk)(struct v4l2_subdev *subdev, int hz);
+ int (*configure_interface)(struct v4l2_subdev *subdev, u32 pixclk);
Platform data is used by board code and should be defined in
include/media/mt9v113.h.
+/*i2c adress for MT9V113*/
+#define MT9V113_I2C_ADDR (0x78 >> 1)
+#define I2C_ONE_BYTE_TRANSFER (1)
+#define I2C_TWO_BYTE_TRANSFER (2)
+#define I2C_THREE_BYTE_TRANSFER (3)
+#define I2C_FOUR_BYTE_TRANSFER (4)
+#define I2C_TXRX_DATA_MASK (0x00FF)
+#define I2C_TXRX_DATA_MASK_UPPER (0xFF00)
+#define I2C_TXRX_DATA_SHIFT (8)
+#define MT9V113_VGA_30FPS (1130)
+#define MT9V113_QVGA_30FPS (1131)
+#define MT9V113_CLK_MAX (54000000) /* 54MHz */
+#define MT9V113_CLK_MIN (6000000) /* 6Mhz */
Everything else is only needed by mt9v113.c and can be moved there.
+#endif /* ifndef _MT9V113_H */
diff --git a/include/media/v4l2-chip-ident.h
b/include/media/v4l2-chip-ident.h index b3edb67..a3446cf 100644
--- a/include/media/v4l2-chip-ident.h
+++ b/include/media/v4l2-chip-ident.h
@@ -297,6 +297,7 @@ enum {
V4L2_IDENT_MT9T112 = 45022,
V4L2_IDENT_MT9V111 = 45031,
V4L2_IDENT_MT9V112 = 45032,
+ V4L2_IDENT_MT9V113 = 45033,
This isn't needed anymore with the media controller API, subdevs can be
identified through their entity name.
Hi Vaibhav,
Thanks for your email.
kernel patches
setup the formats:
found at:
that will work for both sensors.[Hiremath, Vaibhav] Joel,
[Joel]
I'm sorry, actually the intent of the RFC was to get immediate VGA
camera support to Beagle users and some testing with our kernel. The
other intention was to help your team with the differences in what has
changed across the kernels as a reference so that you reuse some of
the work. Certainly I was not going to claim authorship or make the
final submission.
About Signed-off-by lines (if that's what you refer to about
authorship), I intentionally didn't include it in my temporary git
tree as I wanted to make sure if I could use it without permission. My
intention was to rebase and include the relevant SOB lines after I got
clarification on this. Could you suggest a general rule about SOB
lines and whether these can be used without permission when you
reuse/adapt a patch?
I hoped that the words "borrowed from PSP" in the commit summary, the
relevant links to the commits in your tree in the commit summaries and
the retaining of copyright information in the code made it clear that
I was not the original author.
I understand that it is a bit frustrating to see someone take your
code when its not yet complete, anyway I hope my commits help in some
way. Atleast there might be a few people who test your code on the
Beagle and give your team some valuable feedback.
Joel
From: linux-media-owner@vger.kernel.org [mailto:linux-media-
owner@vger.kernel.org] On Behalf Of Laurent Pinchart
Sent: Thursday, July 14, 2011 3:50 AM
To: Joel A Fernandes
Cc: beagleboard@googlegroups.com; Kridner, Jason; Javier Martin; linux-
media@vger.kernel.org; Kooi, Koen; Prakash, Punya; Maupin, Chase; Kipisz,
Subject: Re: [RFC v1] mt9v113: VGA camera sensor driver and support for
BeagleBoardHi Joel,
> kernel patches * Adapted to changes in v4l2 framework and ISP driverHere are a few comments about the code. I've left political issues aside
on
purpose.
[Hiremath, Vaibhav] As always thanks for your comments.
Laurent,
But here the question is nowhere related to politics. I do not care about authorship at all; this is completely engineering argument/discussion I have with this patch.
I have been working with community since long time now, so I was not in favor of submitting this patch with so many known issues (from both feature and cleanliness). If you look at all the comments you provided, most of them should have been already part of the patch series. I wanted them to fix before submitting it to the linux-media, it doesn't matter whether it's RFC.
Another point FYI, the sensor driver has been written during 2.6.37 timeframe, where media-controller was still under flux. Since I wanted to make our production release with MC framework, I pulled in patches from your private branch and started developing from there, so definitely there will be various issues with the driver Vs the current mainline status.
If I would have been aware that, somebody is willing to push my patches, I could have helped him or worked with him (that will ease my bandwidth).
I just made my stand clear here, and I think we should park this discussion here now. We talked enough on this, and I believe we all understand this.
Vaibhav
owner@vger.kernel.org] On Behalf Of Joel A Fernandes
Sent: Thursday, July 14, 2011 6:49 AM
Subject: Re: [beagleboard] [RFC v1] mt9v113: VGA camera sensor driver and
support for BeagleBoardHi Vaibhav,
>> kernel patches
and
sensor,
OE
>> 2.6.39-mt9v113
>> setup the formats:
be
>> found at:
>> Note:
so
the below commit -
for linux-media.
[Joel]I'm sorry, actually the intent of the RFC was to get immediate VGA
[Hiremath, Vaibhav] If you had posted this to beagle list alone, I wouldn't had any issues and that's what I was expecting when we discussed internally.
For me beagle list is custom list and for beagle developers on their kernel version (like 2.6.39 here).
The
final submission.About Signed-off-by lines (if that's what you refer to about
I have issues with the technical contents of the patch itself, so if you would have submitted patch with my knowledge, I would have helped you atleast in review before submitting (that would have saved us from this noise).
Vaibhav
Hi Vaibhav,
> on purpose.As always thanks for your comments.
Laurent,
with this patch.I have been working with community since long time now, so I was not in
I totally agree with you on this. That's why I haven't done any in-depth
review of the patch, but just quickly looked through it.
Joel,
I gave this a try this weekend. I ran into a few problems/questions.
I wanted to try with pre-built (tested?) binaries so I grabbed yours
(used your uImage):
1. media-ctl binary does not work because there is no libmediactl.so
on my Angstrom root FS.
2. There was no yavta-nc application.
I googled and found Laurent's git.ideasonboard.org site and cloned the
media-ctl and yavta projects and built those.
1. The second media-ctl invocation in streams.sh fails with "error
parsing format".
2. The yavta app fails trying to do a "stream on" (maybe due to
media-ctl failure)?
Mark
have you tried 'opkg update ; opkg install mediactl yavta-nc' ?
Dear Mark,
Thanks for trying this out.
media-ctl/yavta commands you could use to get it to show a picture can be found at:
http://utdallas.edu/~joel.fernandes/stream.shJoel,
(used your uImage):
You could install the packages Koen mentioned and then use my
media-ctl binary, that would make sure you have all the library
dependencies.
You could also try copying my libmediactl.so from [1] to /usr/lib/ and
run 'ldconfig', but that would be sort of a hack ![]()
Joel
Yes and no. I tried finding the mediactl package but failed because it
is actually
called media-ctl. Poor searching/naming skills. Thanks for the help. I
will try again tonight.
Mark
Showing my Angstrom ignorance here, but I cannot get these packages
via opkg update. I use Narcissus builder - I built a new FS yesterday
using 2011.03 - should I have used "next". It runs fine, but when I do
the opkg update; opkg install yavta-nc it fails. I see media-ctl and
yavta-nc in the package browser website, but my guess is they are for
"newer" builds?
Mark
Joel,
(used your uImage):
2. There was no yavta-nc application.have you tried 'opkg update ; opkg install mediactl yavta-nc' ?
"newer" builds?
What is the failure? If you have some output, could you paste it?
As a last resort, you could download the .ipk from Angstrom Package
browser, and uncompress it to get yavta-nc
Joel
The error is what you would expect: "package not found"
I did try downloading the .ipk, but it fails to install because "libc6
is too old". If I try to update libc6, it says it is already the
latest. This is the point about being on an old release (2011.03 vs
next).
Mark
(I trimmed the list as most of this probably is of little interest to
many others)
Ok, so I generated a new FS using "next" and installed media-ctl and
yavta-nc via opkg. This left me with the same results as when I built
the test apps myself. Anyway, here's the output:
root@beagleboard:~# ./stream.sh
+ media-ctl -r -l '"mt9v113 2-003c":0->"OMAP3 ISP CCDC":0[1], "OMAP3
ISP CCDC":1->"OMAP3 ISP CCDC output":0[1]'
Resetting all links to inactive
Setting up link 16:0 -> 5:0 [1]
Setting up link 5:1 -> 6:0 [1]
+ media-ctl -f '"mt9v113 2-003c":0[YUYV8_2X8 640x480], "OMAP3 ISP
CCDC":0[YUYV8_2X8 640x480], "OMAP3 ISP CCDC":1[YUYV8_2X8 640x480]'
Unable to parse format
++ media-ctl -e 'OMAP3 ISP CCDC output'
+ yavta-nc --stdout -f YUYV -s 640x480 -n 4 --capture=10 --skip 3 -F /dev/video2
Device /dev/video2 opened: OMAP3 ISP CCDC output (media).
Video format set: width: 640 height: 480 buffer size: 614400
Video format: YUYV (56595559) 640x480
4 buffers requested.
length: 614400 offset: 0
Buffer 0 mapped at address 0x4023c000.
length: 614400 offset: 614400
Buffer 1 mapped at address 0x4032a000.
length: 614400 offset: 1228800
Buffer 2 mapped at address 0x403cf000.
length: 614400 offset: 1843200
Buffer 3 mapped at address 0x404ea000.
Unable to start streaming: 22.
And the corresponding kernel debug output:
[ 1122.190399] BB Debug: Powering on
[ 1122.194183] BB Debug: Regulator 1v8 switching on
[ 1122.201965] BB Debug: Regulator 2v8 switching on
[ 1122.251739] BB Debug: Setting isp xclk
[ 1122.255737] omap3isp omap3isp: isp_set_xclk(): cam_xclka set to 24685714 Hz
[ 1122.255950] Sensor Debug: Default configuration of regs
[ 1122.261291] mt9v113 2-003c: mt9v113_write_reg reg=0x18, val=0x4028
[ 1122.374847] mt9v113 2-003c: mt9v113_write_reg reg=0x1a, val=0x11
[ 1122.381439] mt9v113 2-003c: mt9v113_write_reg reg=0x1a, val=0x10
[ 1122.389007] mt9v113 2-003c: mt9v113_write_reg reg=0x18, val=0x4028
[ 1122.499603] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2f0
[ 1122.506378] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x0
[ 1122.513916] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2f2
[ 1122.521331] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x210
[ 1122.528778] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2f4
[ 1122.536193] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x1a
[ 1122.543518] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2145
[ 1122.550994] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x2f4
[ 1122.558410] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa134
[ 1122.566192] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x1
[ 1122.573425] mt9v113 2-003c: mt9v113_write_reg reg=0x31e0, val=0x1
[ 1122.580810] mt9v113 2-003c: mt9v113_write_reg reg=0x1a, val=0x210
[ 1122.588165] mt9v113 2-003c: mt9v113_write_reg reg=0x1e, val=0x777
[ 1122.595489] mt9v113 2-003c: mt9v113_write_reg reg=0x16, val=0x42df
[ 1122.602874] mt9v113 2-003c: mt9v113_write_reg reg=0x14, val=0x2145
[ 1122.610290] mt9v113 2-003c: mt9v113_write_reg reg=0x14, val=0x2145
[ 1122.617706] mt9v113 2-003c: mt9v113_write_reg reg=0x10, val=0x431
[ 1122.624389] mt9v113 2-003c: mt9v113_write_reg reg=0x12, val=0x0
[ 1122.631805] mt9v113 2-003c: mt9v113_write_reg reg=0x14, val=0x244b
[ 1122.639190] mt9v113 2-003c: mt9v113_write_reg reg=0x14, val=0x304b
[ 1122.749725] mt9v113 2-003c: mt9v113_write_reg reg=0x14, val=0xb04a
[ 1122.756500] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xab1f
[ 1122.764251] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xc7
[ 1122.771575] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xab31
[ 1122.779083] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x1e
[ 1122.786376] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x274f
[ 1122.793884] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x4
[ 1122.801086] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2741
[ 1122.808593] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x4
[ 1122.815826] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xab20
[ 1122.823364] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x54
[ 1122.830749] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xab21
[ 1122.838317] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x46
[ 1122.845947] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xab22
[ 1122.853454] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x2
[ 1122.860687] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xab24
[ 1122.868164] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x5
[ 1122.875427] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2b28
[ 1122.882934] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x170c
[ 1122.889831] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2b2a
[ 1122.897613] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x3e80
[ 1122.905090] mt9v113 2-003c: mt9v113_write_reg reg=0x3210, val=0x9a8
[ 1122.912597] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2306
[ 1122.920135] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x315
[ 1122.927612] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2308
[ 1122.935150] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xfddc
[ 1122.942932] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x230a
[ 1122.950439] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x3a
[ 1122.957763] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x230c
[ 1122.965270] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xff58
[ 1122.972747] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x230e
[ 1122.980255] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x2b7
[ 1122.987731] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2310
[ 1122.995239] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xff31
[ 1123.002746] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2312
[ 1123.010253] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xff4c
[ 1123.017761] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2314
[ 1123.025238] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xfe4c
[ 1123.032989] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2316
[ 1123.040496] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x39e
[ 1123.047912] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2318
[ 1123.055419] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x1c
[ 1123.062713] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x231a
[ 1123.069610] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x39
[ 1123.077178] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x231c
[ 1123.084686] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x7f
[ 1123.092010] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x231e
[ 1123.099487] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xff77
[ 1123.106964] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2320
[ 1123.114471] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xa
[ 1123.121734] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2322
[ 1123.129608] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x20
[ 1123.137023] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2324
[ 1123.144592] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x1b
[ 1123.151916] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2326
[ 1123.159423] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xffc6
[ 1123.166900] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2328
[ 1123.174407] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x86
[ 1123.181762] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x232a
[ 1123.189239] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xb5
[ 1123.196563] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x232c
[ 1123.204040] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xfec3
[ 1123.211547] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x232e
[ 1123.219329] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x1
[ 1123.225921] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2330
[ 1123.233703] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xffef
[ 1123.241210] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa348
[ 1123.248718] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x8
[ 1123.255920] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa349
[ 1123.263427] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x2
[ 1123.270660] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa34a
[ 1123.278167] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x90
[ 1123.285491] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa34b
[ 1123.292968] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xff
[ 1123.300384] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa34c
[ 1123.307891] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x75
[ 1123.315460] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa34d
[ 1123.322967] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xef
[ 1123.330352] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa351
[ 1123.337890] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x0
[ 1123.345184] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa352
[ 1123.352752] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x7f
[ 1123.360076] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa354
[ 1123.367553] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x43
[ 1123.374267] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa355
[ 1123.382019] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x1
[ 1123.389251] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa35d
[ 1123.396728] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x78
[ 1123.404022] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa35e
[ 1123.411804] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x86
[ 1123.419128] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa35f
[ 1123.426635] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x7e
[ 1123.433929] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa360
[ 1123.441406] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x82
[ 1123.448730] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2361
[ 1123.456207] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x40
[ 1123.463531] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa363
[ 1123.471099] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xd2
[ 1123.478424] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa364
[ 1123.485931] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xf6
[ 1123.493286] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa302
[ 1123.501037] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x0
[ 1123.508300] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa303
[ 1123.515777] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xef
[ 1123.522491] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xab20
[ 1123.530242] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x24
[ 1123.537628] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa103
[ 1123.545196] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x6
[ 1123.655761] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa103
[ 1123.662628] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x5
[ 1123.772888] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x222d
[ 1123.779754] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x88
[ 1123.787628] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa408
[ 1123.795166] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x20
[ 1123.802490] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa409
[ 1123.809967] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x23
[ 1123.817382] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa40a
[ 1123.824890] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x27
[ 1123.832183] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa40b
[ 1123.839691] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x2a
[ 1123.846984] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2411
[ 1123.854492] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x88
[ 1123.861785] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2413
[ 1123.869293] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xa4
[ 1123.876861] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2415
[ 1123.884338] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x88
[ 1123.891662] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2417
[ 1123.899139] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0xa4
[ 1123.906433] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa404
[ 1123.913360] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x10
[ 1123.920989] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa40d
[ 1123.928558] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x2
[ 1123.935821] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa40e
[ 1123.943328] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x3
[ 1123.950531] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa103
[ 1123.958038] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x6
[ 1124.069824] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa103
[ 1124.076721] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x5
[ 1124.186950] Sensor Debug: Writing to regs for VGA mode
[ 1124.192199] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2739
[ 1124.200286] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x0
[ 1124.207611] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x273b
[ 1124.215209] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x27f
[ 1124.222625] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x273d
[ 1124.230133] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x0
[ 1124.237365] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x273f
[ 1124.244903] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x1df
[ 1124.252655] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2703
[ 1124.260192] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x280
[ 1124.267669] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0x2705
[ 1124.275177] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x1e0
[ 1124.282592] mt9v113 2-003c: mt9v113_write_reg reg=0x98c, val=0xa103
[ 1124.290069] mt9v113 2-003c: mt9v113_write_reg reg=0x990, val=0x5
[ 1124.405761] Sensor Debug: Sensor Power switched
[ 1124.436492] ISP Debug: isp_video_streamon
[ 1124.441772] ISP Debug: 2
[ 1124.444458] ISP Debug: 3
[ 1124.447174] ISP Debug: Error detected. Something bad happened
Hi Mark,
Thanks for continuing to try this early version of the driver
Do I need a new .so as well:
root@beagleboard:~# wget http://utdallas.edu/~joel.fernandes/media-ctl
--2011-07-28 03:24:51-- http://utdallas.edu/~joel.fernandes/media-ctl
Resolving utdallas.edu... 129.110.10.36
Connecting to utdallas.edu|129.110.10.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 14372 (14K) [text/plain]
Saving to: `media-ctl.1'
100%[======================================>] 14,372 --.-K/s in 0.1s
2011-07-28 03:24:52 (101 KB/s) - `media-ctl.1' saved [14372/14372]
root@beagleboard:~# chmod +x ./media-ctl
+ ./media-ctl -r -l '"mt9v113 2-003c":0->"OMAP3 ISP CCDC":0[1], "OMAP3
+ ./media-ctl -f '"mt9v113 2-003c":0[YUYV8_2X8 640x480], "OMAP3 ISP
Buffer 0 mapped at address 0x40230000.
Buffer 1 mapped at address 0x40314000.
Buffer 2 mapped at address 0x4044c000.
Buffer 3 mapped at address 0x40509000.
^C
root@beagleboard:~#
Saving to: `media-ctl.1'100%[======================================>] 14,372 --.-K/s in 0.1s
You should rename the media-ctl.1 from wget to media-ctl
Joel
root@beagleboard:~# rm media-ctl*
--2011-07-28 04:41:15-- http://utdallas.edu/~joel.fernandes/media-ctl
Saving to: `media-ctl'
2011-07-28 04:41:16 (120 KB/s) - `media-ctl' saved [14372/14372]
root@beagleboard:~# chmod +x media-ctl
Buffer 0 mapped at address 0x4028f000.
Buffer 1 mapped at address 0x403aa000.
Buffer 2 mapped at address 0x4052f000.
Buffer 3 mapped at address 0x406a9000.
^C
