I want to switch the RS232 cape of my Beaglebone from UART2 to UART1
(to get some SPI pins freed...).
In the board file I found these settings:
/* Module pin mux for uart2 */
static struct pinmux_config uart2_pin_mux[] = {
{"spi0_d0.uart2_txd", OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{"spi0_sclk.uart2_rxd", OMAP_MUX_MODE1 | AM33XX_PIN_INPUT_PULLUP},
{NULL, 0},
and
static struct pinmux_config uart1_pin_mux[] = {
{"uart1_txd.uart1_txd", OMAP_MUX_MODE0 | AM33XX_PULL_ENBL},
{"uart1_rxd.uart1_rxd", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
{NULL, 0},
UART2 is the default for the RS232.cape
I stumbled across the setting "AM33XX_PIN_OUTPUT" of UART2 in
comparison to "AM33XX_PULL_ENBL" of UART1.
Is this difference due to a difference in the hardware and should
not be touched or should I use the settings of UART2 for UART1 simply
because I will use UART1 instead of UART2 now?
...I am a little anxious of damaging the hardware here...
What is the correct settings to achieve what I want to do?
Thank you very much in adance for any help!
Have a nice weekend!
Best regards,
mcc
