I am trying to make my Rogers LTE Rocket Stick work with Beagelbone.
So far:
I know the stick works because I tested it with Windows Xp and it works like a charm.
I also tested in with a recent version of Ubuntu on my desk top machine. It also works perfectly.
Here is the result of:
root@beaglebone:~#ifconfig
wwan0 Link encap:Ethernet HWaddr 46:D0:8F:4E:01:07
UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
- root@beaglebone:~# lsusb
Bus 001 Device 003: ID 1199:68a3 Sierra Wireless, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
From the Sierra Wireless web site:
We suggest adding the following lines in the interface file located:
/etc/network/interfaces using any text editor
auto wwan0
iface wwan0 inet dhcp
- When I tried that from the console I got:
root@beaglebone:~# iface wwan0 inet dhcp
-sh: iface: command not found
root@beaglebone:~# iwconfig wwan0 inet dhcp
iwconfig: unknown command “inet”
root@beaglebone:~#
- Apparently this is the APN setting for Rogers, however the driver has changed and no longer supports “AT” commands.
Rogers LTE: at+cgdcont=1,”IP”,”lteinternet.apn “
Anyone have any ideas ??
Bill
