Hi, all. My question is that:
I need to make use a Rom code’s raw mode of reading its payloads from both SD cards and eMMC.
My question is whether the CH (Configuration Header) needed in this case?
TI’s TRM on Sitara am335x states CH must be located at the sector #0,
and says it might be void (only containing a disabled CHSETTINGS item),
but it is very unclear with respect of its size and offsets. and also it’s not clear whether it’s needed at all.
Quote:
“The raw mode is detected by reading sectors #0, #256, #512, #768.
The content of these sectors is then verified for presence of a TOC structure as described in Section 26.1.9.”
But section 26.1.9 even doesn’t mention CH, just a GP header.
And the TRM on Sitara 572x states CH is optional for GP devices.
I mean, if I place my binary into LBA #0 (first sector) with the only GP header attached and no CH,
would the Rom code load it?
I can’t use MBR/FAT mode, because there is GPT and PMBR there.
I wanted to learn this, and before bothering you, I checked eMMC content on BBB,
since TI’s TRM states for embedded memories ROM code doesn’t use MBR/FAT mode.
So on eMMC there should be a valid example of CH with TOC in the first sector. But on BBB, somehow,
and it is clearly seen, the FAT/MBR is used and there is no any TOC at all (first bytes
of the first sector are filled with zeros up to the Partition records). TRM states if the first
4 bytes are 0x00 or 0xFF this device is considererd as not containig the image to load:
Quote
"The detection of whether an image is present or not on a selected device depends on the first few bytes.
On a GP Device type a booting image is considered to be present when the first four bytes of the sector is
not equal to 0000 0000h or FFFF FFFFh."
Maybe there are some knowledgeable people here,
tell me please, is CH needed (for the Romcode) in the raw mode for GP memory booting and
what its minimal content is? Because I cannot let it occupy the entire 512 byte, only part
of the code block (first 440 bytes) of the Protective MBR may be used.
