root@beaglebone:~# ./App
QWSSocket::connectToLocalFile could not connect:: No such file or directory
No Qt for Embedded Linux server appears to be running.
If you want to run this program as a server,
add the “-qws” command-line option.
it depends on how you build Qt sources. There are a number of options and you should explicitly specify if you want QWS or X11 support. You can’t run applications built for QWS under X11 and vice versa
well, Angstrom has no support, but it is more tiny and strongly optimized for Cortex-A8 and therefore much faster than the generally compiled Debian. However Debian’s “apt-get install” is priceless for faster starting
