RTC for AI64
Has anyone successfully setup RTC hardware on an AI64? Details please and thank you!
Which external RTC hardware are you looking at? i2c/spi/1wire?
Thanks Robert!
True confessions . . . this is my first attempt at setting up RTC hardware so I’m not sure which will work or is best.
With a lil Googlin’, I’ve found that this one . . . Adafruit DS3231 Precision RTC Breakout : ID 3013 : $17.50 : Adafruit Industries, Unique & fun DIY electronics and kits . . . apparently works with the BeagleBone Black. I was about to take the time to see if there are matching pins on the AI64 to get it to work.
Then I thought, maybe someone else has already invented this wheel. So I posted on this forum.
Any advice?
Peace . . . Vince
HI @vinceco that shouldn’t be too bad, it’s an i2c device, we just need to port this example from am335x to the bbai64…
You can start with the i2c node here:
While this section will be discovered by trial n error (booting up)…
As far as the application goes . . . I am designing a gizmo without internet access but has the need for an RTC.
Greetings Robert!
Thanks for the links.
I have ordered the DS3231.
I will post progress here.
Peace . . . Vince
Greetings Robert! I just realized that I never got back to ya on this. It turned out that for this project, having an accurate date/time is not required. Thanks again for your pointers, I will keep the hardware for future dev. Peace . . . Vince
