Hi all
Hi Folks,
I have installed a MS518SE-FL35E battery after removing R65 on the
Beagleboard about 2 months back. Though initially, the RTC worked as
expected, over the last couple of days I have noticed that the RTC
loses all time information if the board is powered off for more than 8
hours or so. If the board is powered off for an hour or two, the RTC
retains the time information correctly.
I have checked the voltage across the battery when the RTC is powered
off, it shows about 2.3V. I have noticed this behavior with 2
different boards.
The only "wrong" action I can think of is that the board is always
powered off by turning off the power supply instead of being properly
shutdown by software. This is a requirement of the application that
it is being used for. Would this incorrect powering off affect the way
the PMIC sets up the RTC in poweroff state?
I use Angstrom from OE as the operating system and am running the
linux-omap-psp-2.6.32 kernel which has the following patch 0035-RTC-
add-support-for-backup-battery-recharge.patch included.
I got the similar RTC issue. Normally, the hardware clock can keep
preset time for some days even if it is
powered off or recycle. But this time I found it is changed when I
reboot C4 BB. the linux kernel boot messages
show
twl_rtc twl_rtc: setting system clock to 2000-01-01 00:46:44 UTC
(946687604)
I looked at rtc driver, it reads time from the hardware. I just wonder
how this time is set from a battery
backed-up hardware clock.
Hi Kai
> Hi Folks,
> different boards.
show
(946687604)
I have the same rtc reseting issue. when i reboot or shutdown the
system. the rtc time and system is ok, but if I reset the CPU (via
reset pin of the cpu over a pmic), the rtc time will lost. when system
boot again, it will show
setting system clock to 2000-01-01 00:46:44 UTC (946687604)...
anyone have any clues?
many thanks
