I would like to integrate Wi-Fi in my Beagleboard xM, with the use of Belkin N150 Surf WiFi Dongle.
However, I have noticed that rtl8192cu driver which is preloaded along with Ubuntu 12.04, is not working (dmesg gives me the result “wlan0: link is not ready” while I can find networks with “iwlist scan”).
Yes I have turned down the eth0 interface through /etc/network/interfaces file. However, I won’t have WiFi available. The only changes I have applied are the following:
I would like to ask one more question: Could it be possible to find a dongle that works with my Beagleboard xM out-of-the-box, without any special driver configuration?
I have a Netgear N150 dongle (WNA1100). It worked once and then died. I think the problem might be power supply. Have you tried to use a powered usb hub?
I haven’t tried that, but I don’t think that this is the case… How did you make it work? Did you use the same rtl8192cu driver? Have you tested anything else since that?
I did not use any customised driver. The lsmod indicates the driver is ath9k_htc, not rtl8192cu. I searched for compatible dongles here:http://wireless.kernel.org/en/users/Drivers
And then I just specify the configuration in the /etc/network/interfaces
By the way, usb hub power is not the problem, I tried a usb hub w.o power today. It works just fine.
I see… I can’t really figure out what’s happening. I just want to get my Beagle xM connected without the need of an Ethernet cable. If anyone else has already tried something different, please let us know.
