I have an application that I would rather not have tied up in a loop pooling for when something needs done. This application however needs to begin running when a pin changes level. What would be the best way to do this on the beagle bone?
Eric
Eric
the beagle bone?
You could let the operating system poll for you on the GPIO SYSFS
entry[1], avoiding any usage of the CPU doing silly things like
spinning in loops. I found the RidgeRun example[2] to be particularly
useful.
Better yet, with devicetree, you could simply make an instance of the
gpio-keys driver. This would turn the GPIO change into a keypress
event where you can use any common mechanism for monitoring
events/keypresses to trigger your application to continue.
[1] https://www.kernel.org/doc/Documentation/gpio.txt
[2] https://www.ridgerun.com/developer/wiki/index.php/How_to_use_GPIO_signals#Using_poll.28.29_to_monitor_for_GPIO_0_change
You could run menuconfig, add built-in support to the kernel for ‘*’ for Device Drivers—>Input device support—>Keyboards–>GPIO Button
GPIO buttons enable GPOI pins to act like buttons that generate key up and key down events. Then you read the /dev/input/event0 like a file. These are blocking reads rather than polling. I wrote a program that looked for brightness up and brightness down key presses to control the LCD backlight intensity. Then I installed this a service and configured to automatically start after boot.
Read this posting discussing how I got it working on a TI DM8168:
http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/p/248588/872795.aspx#872795
I pasted the important code parts below:
/// Opens the GPIO Buttons /dev/input/event*
/// \param[in] devicePath the input device path, example, /dev/input/event0
/// \return -1 if fails
int lcdBackLightOpen(char * devicePath) {
char name[256] = “Device Unknown”;
//Setup check
if (NULL == devicePath){
printf(“Device path is empty.”);
return -1;
strcpy(m_devicePath, devicePath);
if ((getuid ()) != 0){
printf ("*** Error Must be root to open and input device event queue\n");
return -1;
if(-1 < m_fileDescriptor) {
printf ("*** Warning %s is already open\n", m_devicePath);
return m_fileDescriptor;
//Open Device
m_fileDescriptor = open (devicePath, O_RDONLY);
if (-1 == m_fileDescriptor) {
printf ("*** Error %s is not a valid device.\n", devicePath);
return -1;
//Print Device Name
ioctl (m_fileDescriptor, EVIOCGNAME (sizeof (name)), name);
printf (“Reading From : %s (%s)\n”, m_devicePath, name);
printf("\nKey Map:\n");
printf(" KEY_BRIGHTNESS_INC 0x%02x (%d)\n", KEY_BRIGHTNESS_INC);
printf(" KEY_BRIGHTNESS_DEC 0x%02x (%d)\n", KEY_BRIGHTNESS_DEC);
/// Closes the file decriptor
void lcdBackLightClose(void) {
printf (“closing %s…\n”, m_devicePath);
close(m_fileDescriptor);
m_fileDescriptor = -1;
/// The LCD back light control loop.
/// Monitors for GPIO Button events KEY_BRIGHTNESSUP and KEY_BRIGHTNESSUP
/// \remarks Has no exit path. Relys on a SIGINT to exit
void lcdBackLightControl(void)
struct input_event eventList[64];
int bytesReadCount = 0;
int eventCount = 0;
int eventIndex = 0;
while (1){
bytesReadCount = read (m_fileDescriptor, eventList, sizeof(eventList));
if( (int)sizeof(struct input_event) > bytesReadCount ){
//perror_exit (“read()”);
continue;
eventCount = bytesReadCount / (int)sizeof(struct input_event);
//printf("\nbytesReadCount %d, events %d\n", bytesReadCount, eventCount);
for( eventIndex = 0; eventIndex < eventCount; eventIndex++)
//lcdBackLightPrintEvent(&eventList[eventIndex]);
// Only read the key press (0x01) or key repeat (0x02) events
// Not sure where input_event value constants are defined if anywhere.
if ((EV_KEY == eventList[eventIndex].value || EV_REL == eventList[eventIndex].value ) &&
(EV_KEY == eventList[eventIndex].type)){
if( KEY_BRIGHTNESS_INC == eventList[eventIndex].code){
lcdBackLightUp();
else if( KEY_BRIGHTNESS_DEC == eventList[eventIndex].code){
lcdBackLightDown();
