So just thinking for a minute. A Raspberry PI 2, the new board with quad cores, and 1 GB ram would probably work fairly decent as a build system for the Beaglebones. Granted, something like the X15, of that new nVidia ARM board, or even the Omelex A20 board with SATA would probably be a much better choice if cost is not a problem.
By the way, I have no idea what Robert is talking about. You need to ask him.
I understand. Well, I did have some little experience with crosscompiling std projects and wiritng in eclipse thanks to Derek Molloys tutorials. All my problems really started when I had to use Qt for beagle. And yes I cant say Im a pro at this stuff…
The idea with a separate board is good I think, I will definetly look for a strong and cheap one. i have never thought of doing it this way though, I always thought people use QEMU and etc.
Thank you for your advices, I really am gratefull for the time.
Robert, If you could please explain me how can I get Qt 5.3.2 on lxqt target you linked I would be really gratefull. I only knew how to install 4.8.2, but that one does not support QSerialport and my code is not not compatible. For now I just wanted to compile my application to show that it works. I would really apreciate your further help.
This is an Octacore processor with 4 CortexA15 and 4 CortexA7 processors. I don’t know how good their kernel/debian support is, but I know Robert had looked at this board or a predecessor in the past, so perhaps he can give his input here.
Clearly this board doesn’t have the flexibility of the BeagleBoard-x15 with it’s dual DSP, Dual CortexM4, Quad PRU, SATA interface, PCIe interface, etc.
Ita the 1st one i see with active cooling. Its not as flexible as beagle x15 but is it important if you only want to build code on it?
As for the package, i have downloaded qt 5.3.2 but wasnt able to run the code yey because of some qt version incompabilities. But that something i can fix soon, i just wasnt able now i had go to sleep. The question is why did i need this lxqt image specifically if i had to install anyway?
Hello there,
I managed to set up qt 5.3.2 on the beaglebone. I have build everything there and it took ages but it works :).
Next step is that I need to check either it is possible to run qt app on bbb without gui with qws parameter. Because at the moment when i run it with qws i get QXcbconnection: Could not connect to display. I need to do it like this because thw gui is really really slow.
root@beaglebone:/home/debian/ImpedanceManager-build# DISPLAY=:0 ./ImpedanceManager -qws No protocol specified QXcbConnection: Could not connect to display :0 Aborted
Have you finally solved this problem? If so, could you please give some advice how to fix this problem?
I am stuck in the same place right now. Trying to run an example after cross compiling qt for BBB.
Hi there,
I was not able to solve this. Because of lack of time, I decided to install qt 5+ on the bbb usong apt manager and build serialport (i needed ot and it was not included) on the bbb itself. For now i am stuck with building on bbb without crosscompiling as i wasnt able to set it for qt 5+ as well.
If you would find a solution to this i would be gratefull if you let me know. I still need the qt on bbb in own frame buffer version.
I am not sure about this but I think I read somewhere that QT 5.3.x does not support the “qws” anymore. I run QT 5.3.1 with -platform linuxfb only and it works. I did compile with eglfs but have not been able to get that to work either.
