I understand now that I will have to use a flat panel attached to the
HDMI port via a HDMI to DVI-D cable for the main console. A LG 1953HR
looks suitable for possible imaging and gaming.
A possible application is to take web-cam input, do some processing, I
assume using the DSP maybe, and output the processed video stream via
the S-video port to a TV screen.
What resolution, colour depth and frame rate would it be possible to
output? I was thinking of using a TV for public display using the
console for control.
Would you get a better result streaming to the console?
Cheers. Andrew.
