S-video screen size in Angstrom
I don't have a digital display so im trying to use s-video my bootargs
are 'console=ttyS2,115200n8 omapdss.def_disp=tv omapfb.mode=tv:ntsc
root=/dev/mmcblk0p2 rw rootwait' i displays fine but most of the image
is cut off, is there a way to shrink the screen so i can get the
entire frame to fit.
thanks,
Sean Pushckor
Sean,
Even i am also facing the same issue, the top screen is slightly cut-off.
Is there any way to fit entire frame to a screen.
my framebuffer resolution size is 640x480. i am using ntsc.
Thanks and Regards,
HarishKumar.V
Me too facing the same issue at 800x600.
Regards
Amit Pundir
what are your DSS2 boot args, just out of curosity, i may have an idea
Sean,
my dss bootarg is,
setenv bootargs console=ttyS2,115200n8 omapdss.def_disp=tv omapfb.mode=tv:ntsc root=/dev/mmcblk0p2 init=/init
is there anyway to shrink or fit the full framesize into display.
Thanks and Regards,
HarishKumar.V
