Sample rate of 2kHz
I’m starting in the beaglebone and I’ve read in several forums that PRU is able to give real-time answers using the libpruio library, but I’m not able to use it, I need a 2kHz sample rate in my AD, transform an analog signal into digital In a sampling of 2kHz, one sample every 250 microseconds. I am using a code that I found created for a beagleone black in a beaglebone white, because the sampling rate is small. where is the problem? I appreciate the advice and opinions that can help me. Thank you.
HI Assuero Savio, your question is confusing!
On Sat, 5 Aug 2017 20:26:33 -0700 (PDT),
assuerosteixeira@gmail.com declaimed the
following:
I'm starting in the beaglebone and I've read in several forums that PRU is
able to give real-time answers using the libpruio library, but I'm not able
  Not sure I understand the question... Other than to comment that the
PRU is not a DSP (if that is what you are trying to achieve). (TI's full
name for them is programmable real-time unit & industrial communication
sub-system). From the TRM:
The PRU is a processor optimized for performing embedded tasks that require
manipulation of packed memory mapped data structures, handling of system
events that have tight real-time constraints and interfacing with systems
external to the SoC. The PRU is both very small and very efficient at
handling such tasks.
{Caveat: I'm attempting to interpret multiple PDF specification sheets and
manuals -- so there may be some errors in my thoughts here}
  Note that the ADCs are on the other side of the L3/L4 interconnect --
which may mean access can be hindered by what is running on the ARM
processor. The ADC max rate is 200K/sec -- if the clocks and configuration
are optimal (otherwise the clock has to run through a divider which will
reduce the max rate available)...
  200K/sec => 2K/msec
... seems like it should be doable. You ask for 2K/sec, or 2/msec... But
then you ask for a sample every 0.25msec (250usec), which means you are
asking for 4 samples per msec, not 2! Perhaps some error in specifying the
ADC configuration?
