I have a Beaglebone Black with a fresh flash of the 2015-03-01 Debian image (bone-debian-7.8-lxde-4gb-armhf-2015-03-01-4gb.img) that I cannot scp or rsync large files to.
The debug output from scp shows nothing but “debug2: channel 0: rcvd adjust [number]” notices.
Searching the web suggests:
MTU mis-matches - no, both sides are 1500.
turning off tcp_sack - didn’t help
Enable compression - didn’t help
Try rsync - rsync fails, too
Try tar over ssh directly - didn’t work
Upgrading scp/sshd - did “apt-get upgrade scp” and that freshened up a lot but didn’t help.
Log snippet is below. Any suggestions are appreciated.
philmills@VM64:~/DEV/AUC/dist/BEAGLEBONE$ scp -vv -C ModTests debian@a.b.c.d:/home/debian
Executing: program /usr/bin/ssh host a.b.c.d, user debian, command scp -v -t /home/debian
OpenSSH_6.0p1 Debian-4+deb7u2, OpenSSL 1.0.1e 11 Feb 2013
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to a.b.c.d [a.b.c.d] port 22.
debug1: Connection established.
debug1: identity file /home/philmills/.ssh/id_rsa type -1
debug1: identity file /home/philmills/.ssh/id_rsa-cert type -1
debug1: identity file /home/philmills/.ssh/id_dsa type -1
debug1: identity file /home/philmills/.ssh/id_dsa-cert type -1
debug1: identity file /home/philmills/.ssh/id_ecdsa type -1
debug1: identity file /home/philmills/.ssh/id_ecdsa-cert type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.0p1 Debian-4+deb7u2
debug1: match: OpenSSH_6.0p1 Debian-4+deb7u2 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.0p1 Debian-4+deb7u2
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-sha2-256,hmac-sha2-256-96,hmac-sha2-512,hmac-sha2-512-96,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: zlib@openssh.com,zlib,none
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256
debug2: kex_parse_kexinit: none,zlib@openssh.com
debug2: mac_setup: found hmac-md5
debug1: kex: server->client aes128-ctr hmac-md5 zlib@openssh.com
debug1: kex: client->server aes128-ctr hmac-md5 zlib@openssh.com
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA 15:74:3c:e0:05:6a:34:98:4c:f5:f2:ed:3b:1b:2a:0d
debug1: Host ‘a.b.c.d’ is known and matches the ECDSA host key.
debug1: Found key in /home/philmills/.ssh/known_hosts:5
debug1: ssh_ecdsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: pmills BEC OpenSSH.ppk (0x7f141e16b290)
debug2: key: /home/philmills/.ssh/id_rsa ((nil))
debug2: key: /home/philmills/.ssh/id_dsa ((nil))
debug2: key: /home/philmills/.ssh/id_ecdsa ((nil))
Debian GNU/Linux 7BeagleBoard.org Debian Image 2015-03-01
Support/FAQ: Beagleboard:BeagleBoneBlack Debian - eLinux.org
default username:password is [debian:temppwd]
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Offering RSA public key: pmills BEC OpenSSH.ppk
debug2: we sent a publickey packet, wait for reply
debug1: Trying private key: /home/philmills/.ssh/id_rsa
debug1: Trying private key: /home/philmills/.ssh/id_dsa
debug1: Trying private key: /home/philmills/.ssh/id_ecdsa
debug2: we did not send a packet, disable method
debug1: Next authentication method: password
debian@a.b.c.d’s password:
debug2: we sent a password packet, wait for reply
debug1: Enabling compression at level 6.
debug1: Authentication succeeded (password).
Authenticated to a.b.c.d ([a.b.c.d]:22).
debug2: fd 4 setting O_NONBLOCK
debug2: fd 5 setting O_NONBLOCK
debug1: channel 0: new [client-session]
debug2: channel 0: send open
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug2: callback start
debug2: client_session2_setup: id 0
debug2: fd 3 setting TCP_NODELAY
debug1: Sending environment.
debug1: Sending env LANG = en_US.UTF-8
debug2: channel 0: request env confirm 0
debug1: Sending command: scp -v -t /home/debian
debug2: channel 0: request exec confirm 1
debug2: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug2: channel 0: rcvd adjust 2097152
debug2: channel_input_status_confirm: type 99 id 0
debug2: exec request accepted on channel 0
Sending file modes: C0755 27054794 ModTests
debug2: channel 0: rcvd ext data 33
Sink: C0755 27054794 ModTests
debug2: channel 0: written 33 to efd 6
ModTests 0% 0 0.0KB/s --:-- ETA
debug2: channel 0: rcvd adjust 98331
debug2: channel 0: rcvd adjust 114688
debug2: channel 0: rcvd adjust 131072
debug2: channel 0: rcvd adjust 65536
debug2: channel 0: rcvd adjust 163840
[and so on and so forth until I kill -9 the scp process]
