Scratchbox and BeagleBoard
Hello everyone,
I am currently working with Scratchbox (http://www.scratchbox.org/)
and a generic ARM-based board. This really helps a lot when cross
compiling libraries and programs using binutils (cmake, configure,
make, etc..). However I am seriously thinking of buying a BeagleBoard
XM.
Does any of you tried using Scratchbox together with Beagleboard? Did
you find it easy?
Thanks very much.
Best regards.
Hello everyone,
XM.
you find it easy?
It isn't too bad. Check out
http://linux.onarm.com/index.php/Main_Page. The release process there
on the ARM Linux Internet Platform directly supports the BeagleBoard
and uses Scratchbox.
Thanks very much.
I will give it a try.
Regards :wink:
I use scratchbox2, and basically which hardware platform you use is
mostly irrelevant:
http://felipec.wordpress.com/2010/10/08/my-arm-development-notes/
