I have a problem with a BeagleBone Black, it thinks to be a BBGreen and the screen HDMI does not work. I found this page and tried to apply the proposed cure, without luck.
#> dd if=/opt/scripts/device/bone/bbb-eeprom.dump of=/sys/devices/platform/ocp/44e0b000.i2c/i2c-0/0-0050/eeprom
I am booting the same image via SDcard on two BBBlack, on one the screen works, on the other it does not. I post below the boot messages, first the messages from the BBB that thinkgs to be a BBGreen, and where screen does not work (No Signal).
Do you know how to fix this ?
U-Boot 2019.04-00002-g07d5700e21 (Mar 06 2020 - 11:24:55 -0600), Build: jenkins-github_Bootloader-Builder-137
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: SeeedStudio BeagleBone Green:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[BBG1] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
2062 bytes read in 35 ms (56.6 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.19.94-ti-r42 ...
10095592 bytes read in 665 ms (14.5 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/4.19.94-ti-r42/am335x-boneblack-uboot-univ.dtb ...
162266 bytes read in 111 ms (1.4 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /lib/firmware/M-BB-BBG-00A0.dtbo ...
423 bytes read in 229 ms (1000 Bytes/s)
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo ...
867 bytes read in 33 ms (25.4 KiB/s)
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo ...
1584 bytes read in 238 ms (5.9 KiB/s)
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo ...
3801 bytes read in 209 ms (17.6 KiB/s)
loading /boot/initrd.img-4.19.94-ti-r42 ...
6585227 bytes read in 448 ms (14 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=10.
debug: [bootz 0x82000000 0x88080000:647b8b 88000000] ...
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f9b8000, end 8ffffb8b ... OK
Loading Device Tree to 8f92d000, end 8f9b7fff ... OK
Starting kernel ...
[ 0.002127] timer_probe: no matching timers found
[ 0.191028] l4_wkup_cm:clk:0010:0: failed to disable
[ 1.480440] omap_voltage_late_init: Voltage driver support not added
Debian GNU/Linux 10 beaglebone ttyS0
BeagleBoard.org Debian Buster Console Image 2020-04-06
Support: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
for comparison, here the BBB who knows that it is a BBB
I2C: ready
DRAM: 512 MiB
BeagleBone Black:
Net: eth0: MII MODE
cpsw, usb_ether
board_name=[A335BNLT] ...
board_rev=[000C] ...
Scanning mmc 0:1...
uboot_overlays: loading /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo ...
4915 bytes read in 256 ms (18.6 KiB/s)
6585227 bytes read in 449 ms (14 MiB/s)
Loading Device Tree to 8f92c000, end 8f9b7fff ... OK
Starting kernel ...
[ 0.002165] timer_probe: no matching timers found
[ 0.195742] l4_wkup_cm:clk:0010:0: failed to disable
[ 1.411336] omap_voltage_late_init: Voltage driver support not added
