I’m facing some issues in booting from the SD card. Here is the complete output:
EFI stub: Booting Linux Kernel...
EFI stub: EFI_RNG_PROTOCOL unavailable, KASLR will be disabled
EFI stub: ERROR: FIRMWARE BUG: kernel image not aligned on 64k boundary
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services and installing virtual address map...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.162 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP Mon Mar 20 22:02:35 UTC 2023
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] efi: EFI v2.80 by Das U-Boot
[ 0.000000] efi: RTPROP=0xfcea9040 SMBIOS=0xfcea5000 MEMRESERVE=0xdd2a9040
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000fcde5fff]
[ 0.000000] node 0: [mem 0x00000000fcde6000-0x00000000fcde7fff]
[ 0.000000] node 0: [mem 0x00000000fcde8000-0x00000000fce9cfff]
[ 0.000000] node 0: [mem 0x00000000fce9d000-0x00000000fcea3fff]
[ 0.000000] node 0: [mem 0x00000000fcea4000-0x00000000fcea4fff]
[ 0.000000] node 0: [mem 0x00000000fcea5000-0x00000000fcea5fff]
[ 0.000000] node 0: [mem 0x00000000fcea6000-0x00000000fcea7fff]
[ 0.000000] node 0: [mem 0x00000000fcea8000-0x00000000fceabfff]
[ 0.000000] node 0: [mem 0x00000000fceac000-0x00000000fceacfff]
[ 0.000000] node 0: [mem 0x00000000fcead000-0x00000000fceb1fff]
[ 0.000000] node 0: [mem 0x00000000fceb2000-0x00000000fceb2fff]
[ 0.000000] node 0: [mem 0x00000000fceb3000-0x00000000fceb3fff]
[ 0.000000] node 0: [mem 0x00000000fceb4000-0x00000000fceb5fff]
[ 0.000000] node 0: [mem 0x00000000fceb6000-0x00000000fceb7fff]
[ 0.000000] node 0: [mem 0x00000000fceb8000-0x00000000fceb8fff]
[ 0.000000] node 0: [mem 0x00000000fceb9000-0x00000000fceb9fff]
[ 0.000000] node 0: [mem 0x00000000fceba000-0x00000000fcebbfff]
[ 0.000000] node 0: [mem 0x00000000fcebc000-0x00000000fcebcfff]
[ 0.000000] node 0: [mem 0x00000000fcebd000-0x00000000ffeeffff]
[ 0.000000] node 0: [mem 0x00000000ffef0000-0x00000000ffefffff]
[ 0.000000] node 0: [mem 0x00000000fff00000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 144 MiB at 0x00000000f3c00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s92952 r8192 d29928 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: BOOT_IMAGE=/Image root=PARTUUID=7aa8b068-02 rootwait rootfstype=ext4 ro
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000efc00000-0x00000000f3c00000] (64MB)
[ 0.000000] Memory: 3670192K/4194304K available (17152K kernel code, 2268K rwdata, 5348K rodata, 3776K init, 724K bss, 376656K reserved, 147456K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008800d0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800e0000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000168] Console: colour dummy device 80x25
[ 0.000481] printk: console [tty0] enabled
[ 0.000508] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000517] pid_max: default: 32768 minimum: 301
[ 0.000652] LSM: Security Framework initializing
[ 0.000678] Yama: becoming mindful.
[ 0.000753] AppArmor: AppArmor initialized
[ 0.000762] TOMOYO Linux initialized
[ 0.000834] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000859] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001925] rcu: Hierarchical SRCU implementation.
[ 0.002511] Platform MSI: msi-controller@1820000 domain created
[ 0.002646] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.002687] Remapping and enabling EFI services.
[ 0.002922] smp: Bringing up secondary CPUs ...
[ 0.003608] Detected PIPT I-cache on CPU1
[ 0.003629] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.003664] GICv3: CPU1: using allocated LPI pending table @0x00000008800f0000
[ 0.003699] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.003766] smp: Brought up 1 node, 2 CPUs
[ 0.003784] SMP: Total of 2 processors activated.
[ 0.003790] CPU features: detected: 32-bit EL0 Support
[ 0.003796] CPU features: detected: CRC32 instructions
[ 0.003800] CPU features: detected: 32-bit EL1 Support
[ 0.022863] CPU: All CPU(s) started at EL2
[ 0.022913] alternatives: patching kernel code
[ 0.023611] devtmpfs: initialized
[ 0.028463] KASLR disabled due to lack of seed
[ 0.028612] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.028640] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.030804] pinctrl core: initialized pinctrl subsystem
[ 0.031172] SMBIOS 3.0 present.
[ 0.031181] DMI: /, BIOS 2021.01-gf65a2b8f 08/10/2022
[ 0.031568] NET: Registered protocol family 16
[ 0.032314] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.032422] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.032575] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.032634] audit: initializing netlink subsys (disabled)
[ 0.032818] audit: type=2000 audit(0.032:1): state=initialized audit_enabled=0 res=1
[ 0.033047] thermal_sys: Registered thermal governor 'fair_share'
[ 0.033049] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.033055] thermal_sys: Registered thermal governor 'step_wise'
[ 0.033059] thermal_sys: Registered thermal governor 'user_space'
[ 0.033064] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.033279] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.033323] ASID allocator initialised with 32768 entries
[ 0.048879] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.048895] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.048900] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.048905] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.049877] cryptd: max_cpu_qlen set to 1000
[ 0.051480] raid6: skip pq benchmark and using algorithm neonx8
[ 0.051493] raid6: using neon recovery algorithm
[ 0.051944] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.052228] vsys_3v3: supplied by evm_12v0
[ 0.052384] vsys_5v0: supplied by evm_12v0
[ 0.052824] iommu: Default domain type: Translated
[ 0.053089] SCSI subsystem initialized
[ 0.053183] usbcore: registered new interface driver usbfs
[ 0.053200] usbcore: registered new interface driver hub
[ 0.053214] usbcore: registered new device driver usb
[ 0.053511] mc: Linux media interface: v0.10
[ 0.053524] videodev: Linux video capture interface: v2.00
[ 0.053553] pps_core: LinuxPPS API ver. 1 registered
[ 0.053557] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.053566] PTP clock support registered
[ 0.053590] EDAC MC: Ver: 3.0.0
[ 0.053770] Registered efivars operations
[ 0.054527] NetLabel: Initializing
[ 0.054537] NetLabel: domain hash size = 128
[ 0.054540] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.054576] NetLabel: unlabeled traffic allowed by default
[ 0.054840] clocksource: Switched to clocksource arch_sys_counter
[ 0.369647] VFS: Disk quotas dquot_6.6.0
[ 0.369701] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.369792] FS-Cache: Loaded
[ 0.370024] CacheFiles: Loaded
[ 0.370272] AppArmor: AppArmor Filesystem Enabled
[ 0.373473] NET: Registered protocol family 2
[ 0.373782] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.375136] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.375407] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.375729] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.375985] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.376259] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.376377] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.376457] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.376608] NET: Registered protocol family 1
[ 0.377023] RPC: Registered named UNIX socket transport module.
[ 0.377033] RPC: Registered udp transport module.
[ 0.377037] RPC: Registered tcp transport module.
[ 0.377041] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.377048] NET: Registered protocol family 44
[ 0.377060] PCI: CLS 0 bytes, default 64
[ 0.377461] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.377717] kvm [1]: IPA Size Limit: 44 bits
[ 0.378102] kvm [1]: GICv3: no GICV resource entry
[ 0.378109] kvm [1]: disabling GICv2 emulation
[ 0.378130] kvm [1]: GIC system register CPU interface enabled
[ 0.378164] kvm [1]: vgic interrupt IRQ9
[ 0.378224] kvm [1]: Hyp mode initialized successfully
[ 0.380377] Initialise system trusted keyrings
[ 0.380483] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.382592] zbud: loaded
[ 0.383714] NFS: Registering the id_resolver key type
[ 0.383753] Key type id_resolver registered
[ 0.383758] Key type id_legacy registered
[ 0.383811] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.383818] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.383834] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.384414] fuse: init (API version 7.32)
[ 0.404589] xor: measuring software checksum speed
[ 0.405871] 8regs : 7782 MB/sec
[ 0.406972] 32regs : 9065 MB/sec
[ 0.408196] arm64_neon : 8067 MB/sec
[ 0.408200] xor: using function: 32regs (9065 MB/sec)
[ 0.408211] Key type asymmetric registered
[ 0.408216] Asymmetric key parser 'x509' registered
[ 0.408245] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.408319] io scheduler mq-deadline registered
[ 0.409486] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.409749] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.414048] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.415995] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.416312] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.416527] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.418201] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.422479] brd: module loaded
[ 0.554888] loop: module loaded
[ 0.555529] megasas: 07.714.04.00-rc1
[ 0.557808] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.557822] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.557856] sky2: driver version 1.30
[ 0.558440] VFIO - User Level meta-driver version: 0.3
[ 0.558778] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.558797] ehci-pci: EHCI PCI platform driver
[ 0.559113] usbcore: registered new interface driver uas
[ 0.559134] usbcore: registered new interface driver usb-storage
[ 0.559847] i2c /dev entries driver
[ 0.559963] Driver for 1-wire Dallas network protocol.
[ 0.559994] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
[ 0.560733] sdhci: Secure Digital Host Controller Interface driver
[ 0.560739] sdhci: Copyright(c) Pierre Ossman
[ 0.560894] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.561402] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.561716] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.561791] omap_timer 40400000.timer: IRQ index 0 not found
[ 0.561885] hid: raw HID events driver (C) Jiri Kosina
[ 0.561996] usbcore: registered new interface driver usbhid
[ 0.562001] usbhid: USB HID core driver
[ 0.562440] optee: probing for conduit method.
[ 0.562460] optee: revision 3.12 (cac3fef2)
[ 0.562688] optee: initialized driver
[ 0.562872] mmio-mux 47000000.fss:hbmc-mux: failed to get regmap: -22
[ 0.562882] mmio-mux: probe of 47000000.fss:hbmc-mux failed with error -22
[ 0.563401] drop_monitor: Initializing network drop monitor service
[ 0.563760] NET: Registered protocol family 10
[ 0.565257] Segment Routing with IPv6
[ 0.565327] mip6: Mobile IPv6
[ 0.565335] NET: Registered protocol family 17
[ 0.565446] Key type dns_resolver registered
[ 0.565453] mpls_gso: MPLS GSO support
[ 0.565598] registered taskstats version 1
[ 0.565607] Loading compiled-in X.509 certificates
[ 0.565665] zswap: loaded using pool lzo/zbud
[ 0.565784] Key type .fscrypt registered
[ 0.565790] Key type fscrypt-provisioning registered
[ 0.569563] Btrfs loaded, crc32c=crc32c-generic
[ 0.569644] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.575623] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
[ 0.613749] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.614218] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.614704] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.615533] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.615601] pca953x 3-0020: using no AI
[ 0.638885] pca953x 3-0020: failed writing register
[ 0.638945] pca953x: probe of 3-0020 failed with error -121
[ 0.639294] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 0.639350] pca953x 3-0022: using AI
[ 0.639409] pca953x 3-0022: failed writing register
[ 0.639452] pca953x: probe of 3-0022 failed with error -121
[ 0.639531] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.640430] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.640961] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[ 0.641630] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 0.641687] pca953x 6-0020: using no AI
[ 0.662886] pca953x 6-0020: failed writing register
[ 0.662944] pca953x: probe of 6-0020 failed with error -121
[ 0.663377] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.663955] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 0.664406] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 0.665077] pca953x 9-0020: supply vcc not found, using dummy regulator
[ 0.665143] pca953x 9-0020: using no AI
[ 0.686889] pca953x 9-0020: failed writing register
[ 0.686950] pca953x: probe of 9-0020 failed with error -121
[ 0.687045] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[ 0.687863] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 0.687973] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 0.688080] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 0.688240] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 0.699609] OF: /bus@100000/pcie@2900000: phandle syscon@4070 needs 1, found 0
[ 0.699660] ------------[ cut here ]------------
[ 0.699665] j721e-pcie 2900000.pcie: legacy-interrupt-controller node is absent
[ 0.699709] WARNING: CPU: 1 PID: 76 at j721e_pcie_probe+0x620/0x830
[ 0.699713] Modules linked in:
[ 0.699722] CPU: 1 PID: 76 Comm: kworker/1:3 Not tainted 5.10.162 #1
[ 0.699726] Hardware name: /, BIOS 2021.01-gf65a2b8f 08/10/2022
[ 0.699739] Workqueue: events deferred_probe_work_func
[ 0.699746] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 0.699751] pc : j721e_pcie_probe+0x620/0x830
[ 0.699756] lr : j721e_pcie_probe+0x620/0x830
[ 0.699759] sp : ffff8000121e3ad0
[ 0.699763] x29: ffff8000121e3ad0 x28: 0000000000000000
[ 0.699769] x27: ffff000800c16c10 x26: ffff000800c16c10
[ 0.699775] x25: ffff000800c16c10 x24: ffff000800c16c10
[ 0.699782] x23: 0000000000000000 x22: ffff80001136f650
[ 0.699787] x21: ffff000800c16c10 x20: 000000000000001a
[ 0.699793] x19: ffff000801fc5580 x18: ffffffffffffffff
[ 0.699798] x17: 000000007390f425 x16: 00000000bcd7f3f7
[ 0.699804] x15: ffff8000921e3787 x14: 0720072007200720
[ 0.699810] x13: 000000000000014c x12: ffff8000121e3770
[ 0.699815] x11: ffff800011bf9ec0 x10: 00000000fffff800
[ 0.699821] x9 : ffff800011bcdec0 x8 : 00000000fffff7ff
[ 0.699827] x7 : ffff800011bf9ec0 x6 : 0000000000000000
[ 0.699832] x5 : 0000000000000000 x4 : 0000000000000000
[ 0.699838] x3 : 0000000000000000 x2 : 0000000000000000
[ 0.699843] x1 : 0000000000000000 x0 : ffff000800d48ec0
[ 0.699850] Call trace:
[ 0.699855] j721e_pcie_probe+0x620/0x830
[ 0.699860] platform_drv_probe+0x54/0xac
[ 0.699865] really_probe+0xf0/0x500
[ 0.699870] driver_probe_device+0xf4/0x160
[ 0.699875] __device_attach_driver+0xbc/0x140
[ 0.699880] bus_for_each_drv+0x78/0xd0
[ 0.699885] __device_attach+0xa8/0x1e0
[ 0.699890] device_initial_probe+0x14/0x20
[ 0.699895] bus_probe_device+0x9c/0xa4
[ 0.699899] deferred_probe_work_func+0xb4/0x10c
[ 0.699908] process_one_work+0x1c8/0x490
[ 0.699913] worker_thread+0x220/0x4f4
[ 0.699917] kthread+0x124/0x12c
[ 0.699923] ret_from_fork+0x10/0x3c
[ 0.699927] ---[ end trace b7d6f7b29a84eaf3 ]---
[ 0.699972] j721e-pcie: probe of 2900000.pcie failed with error -22
[ 0.700301] OF: /bus@100000/pcie@2910000: phandle syscon@4074 needs 1, found 0
[ 0.700341] ------------[ cut here ]------------
[ 0.700347] j721e-pcie 2910000.pcie: legacy-interrupt-controller node is absent
[ 0.700373] WARNING: CPU: 1 PID: 76 at j721e_pcie_probe+0x620/0x830
[ 0.700377] Modules linked in:
[ 0.700384] CPU: 1 PID: 76 Comm: kworker/1:3 Tainted: G W 5.10.162 #1
[ 0.700389] Hardware name: /, BIOS 2021.01-gf65a2b8f 08/10/2022
[ 0.700396] Workqueue: events deferred_probe_work_func
[ 0.700402] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 0.700407] pc : j721e_pcie_probe+0x620/0x830
[ 0.700412] lr : j721e_pcie_probe+0x620/0x830
[ 0.700416] sp : ffff8000121e3ad0
[ 0.700420] x29: ffff8000121e3ad0 x28: 0000000000000000
[ 0.700426] x27: ffff000800c17c10 x26: ffff000800c17c10
[ 0.700432] x25: ffff000800c17c10 x24: ffff000800c17c10
[ 0.700437] x23: 0000000000000000 x22: ffff80001136f650
[ 0.700443] x21: ffff000800c17c10 x20: 000000000000001b
[ 0.700449] x19: ffff000801fc7180 x18: ffffffffffffffff
[ 0.700454] x17: 00000000c143acef x16: 00000000340e1905
[ 0.700460] x15: ffff8000921e3787 x14: 0720072007200720
[ 0.700466] x13: 0000000000000178 x12: ffff8000121e3770
[ 0.700472] x11: ffff800011bf9ec0 x10: 00000000fffff800
[ 0.700477] x9 : ffff800011bcdec0 x8 : 00000000fffff7ff
[ 0.700483] x7 : ffff800011bf9ec0 x6 : 0000000000000000
[ 0.700488] x5 : 0000000000000000 x4 : 0000000000000000
[ 0.700494] x3 : 0000000000000000 x2 : 0000000000000000
[ 0.700499] x1 : 0000000000000000 x0 : ffff000800d48ec0
[ 0.700506] Call trace:
[ 0.700510] j721e_pcie_probe+0x620/0x830
[ 0.700515] platform_drv_probe+0x54/0xac
[ 0.700520] really_probe+0xf0/0x500
[ 0.700524] driver_probe_device+0xf4/0x160
[ 0.700529] __device_attach_driver+0xbc/0x140
[ 0.700534] bus_for_each_drv+0x78/0xd0
[ 0.700538] __device_attach+0xa8/0x1e0
[ 0.700543] device_initial_probe+0x14/0x20
[ 0.700548] bus_probe_device+0x9c/0xa4
[ 0.700553] deferred_probe_work_func+0xb4/0x10c
[ 0.700558] process_one_work+0x1c8/0x490
[ 0.700563] worker_thread+0x220/0x4f4
[ 0.700567] kthread+0x124/0x12c
[ 0.700572] ret_from_fork+0x10/0x3c
[ 0.700576] ---[ end trace b7d6f7b29a84eaf4 ]---
[ 0.700609] j721e-pcie: probe of 2910000.pcie failed with error -22
[ 0.700941] OF: /bus@100000/pcie@2920000: phandle syscon@4078 needs 1, found 0
[ 0.700976] ------------[ cut here ]------------
[ 0.700981] j721e-pcie 2920000.pcie: legacy-interrupt-controller node is absent
[ 0.701001] WARNING: CPU: 1 PID: 76 at j721e_pcie_probe+0x620/0x830
[ 0.701005] Modules linked in:
[ 0.701011] CPU: 1 PID: 76 Comm: kworker/1:3 Tainted: G W 5.10.162 #1
[ 0.701015] Hardware name: /, BIOS 2021.01-gf65a2b8f 08/10/2022
[ 0.701024] Workqueue: events deferred_probe_work_func
[ 0.701029] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 0.701034] pc : j721e_pcie_probe+0x620/0x830
[ 0.701039] lr : j721e_pcie_probe+0x620/0x830
[ 0.701042] sp : ffff8000121e3ad0
[ 0.701046] x29: ffff8000121e3ad0 x28: 0000000000000000
[ 0.701052] x27: ffff000800c14810 x26: ffff000800c14810
[ 0.701057] x25: ffff000800c14810 x24: ffff000800c14810
[ 0.701063] x23: 0000000000000000 x22: ffff80001136f650
[ 0.701069] x21: ffff000800c14810 x20: 000000000000001c
[ 0.701075] x19: ffff000801fc7a80 x18: ffffffffffffffff
[ 0.701080] x17: 000000005bfbdd1d x16: 000000008479deab
[ 0.701086] x15: ffff8000921e3787 x14: 0720072007200720
[ 0.701092] x13: 00000000000001a4 x12: ffff8000121e3770
[ 0.701097] x11: ffff800011bf9ec0 x10: 00000000fffff800
[ 0.701103] x9 : ffff800011bcdec0 x8 : 00000000fffff7ff
[ 0.701109] x7 : ffff800011bf9ec0 x6 : 0000000000000000
[ 0.701114] x5 : 0000000000000000 x4 : 0000000000000000
[ 0.701120] x3 : 0000000000000000 x2 : 0000000000000000
[ 0.701125] x1 : 0000000000000000 x0 : ffff000800d48ec0
[ 0.701131] Call trace:
[ 0.701136] j721e_pcie_probe+0x620/0x830
[ 0.701140] platform_drv_probe+0x54/0xac
[ 0.701145] really_probe+0xf0/0x500
[ 0.701150] driver_probe_device+0xf4/0x160
[ 0.701154] __device_attach_driver+0xbc/0x140
[ 0.701159] bus_for_each_drv+0x78/0xd0
[ 0.701164] __device_attach+0xa8/0x1e0
[ 0.701168] device_initial_probe+0x14/0x20
[ 0.701173] bus_probe_device+0x9c/0xa4
[ 0.701178] deferred_probe_work_func+0xb4/0x10c
[ 0.701183] process_one_work+0x1c8/0x490
[ 0.701188] worker_thread+0x220/0x4f4
[ 0.701192] kthread+0x124/0x12c
[ 0.701197] ret_from_fork+0x10/0x3c
[ 0.701200] ---[ end trace b7d6f7b29a84eaf5 ]---
[ 0.701232] j721e-pcie: probe of 2920000.pcie failed with error -22
[ 0.702053] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 0.702064] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.702069] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.703905] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 0.703918] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.703924] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.704460] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 0.704980] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 29, base_baud = 3000000) is a 8250
[ 3.324404] printk: console [ttyS2] enabled
[ 3.329652] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 30, base_baud = 3000000) is a 8250
[ 3.338711] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 31, base_baud = 3000000) is a 8250
[ 3.347763] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 32, base_baud = 3000000) is a 8250
[ 3.357159] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 3.367677] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 3.377832] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 3.388076] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 3.399307] scsi host0: ufshcd
[ 3.406175] davinci_mdio 46000000.ethernet:mdio@f00: Configuring MDIO in manual mode
[ 3.413941] davinci_mdio: probe of 46000000.ethernet:mdio@f00 failed with error -22
[ 3.421622] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 3.434497] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 3.441707] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 3.448134] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 3.458472] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 3.468296] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.473804] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 3.481563] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 3.490967] xhci-hcd xhci-hcd.0.auto: irq 220, io mem 0x06410000
[ 3.497170] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.505427] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.512645] usb usb1: Product: xHCI Host Controller
[ 3.517511] usb usb1: Manufacturer: Linux 5.10.162 xhci-hcd
[ 3.523073] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 3.528180] hub 1-0:1.0: USB hub found
[ 3.531944] hub 1-0:1.0: 1 port detected
[ 3.536006] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.541493] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 3.549142] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 3.555692] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.563840] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 3.572089] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.579294] usb usb2: Product: xHCI Host Controller
[ 3.584162] usb usb2: Manufacturer: Linux 5.10.162 xhci-hcd
[ 3.589721] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 3.594773] hub 2-0:1.0: USB hub found
[ 3.598530] hub 2-0:1.0: 1 port detected
[ 3.603805] mmc0: CQHCI version 5.10
[ 3.613977] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 3.620659] pca953x 4-0020: using no AI
[ 3.646890] pca953x 4-0020: failed writing register
[ 3.651173] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[ 3.651822] pca953x: probe of 4-0020 failed with error -121
[ 3.665634] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 3.672537] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 3.679406] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 3.686257] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 3.693069] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 3.703437] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 3.714514] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 3.722263] mmc0: Command Queue Engine enabled
[ 3.727685] mmc0: new HS400 MMC card at address 0001
[ 3.733115] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 3.737783] mmcblk0boot0: mmc0:0001 TB2916 partition 1 4.00 MiB
[ 3.743808] mmcblk0boot1: mmc0:0001 TB2916 partition 2 4.00 MiB
[ 3.749880] mmcblk0rpmb: mmc0:0001 TB2916 partition 3 4.00 MiB, chardev (236:0)
[ 3.758061] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 3.758261] mmcblk0: p1 p2
[ 3.764948] spi-nor: probe of spi0.0 failed with error -2
[ 3.775706] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 3.782594] spi-nor: probe of spi1.0 failed with error -2
[ 3.788695] davinci_mdio 46000000.ethernet:mdio@f00: Configuring MDIO in manual mode
[ 3.796448] davinci_mdio: probe of 46000000.ethernet:mdio@f00 failed with error -22
[ 3.804154] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 3.812247] cdns-ufshcd 4e84000.ufs: link startup failed 1
[ 3.817037] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 3.822395] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[ 3.829596] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 3.840565] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[ 3.840882] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 3.846824] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[ 3.846826] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[ 3.846830] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[ 3.875668] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[ 3.882014] cdns-ufshcd 4e84000.ufs: Clk gate=1
[ 3.886540] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[ 3.894707] cdns-ufshcd 4e84000.ufs: last intr at 3808293 us, last intr status=0x404
[ 3.894743] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 3.902437] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[ 3.902440] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[ 3.902443] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[ 3.931369] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[ 3.937629] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[ 3.943715] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[ 3.949806] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[ 3.961982] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[ 3.968323] host_regs: 00000010: 00000000 00000000 00000000 00000000
[ 3.974664] host_regs: 00000020: 00000000 00000470 00000000 00000000
[ 3.981004] host_regs: 00000030: 00000008 00000001 00000000 00000000
[ 3.987344] host_regs: 00000040: 00000000 00000000 00000000 00000000
[ 3.993684] host_regs: 00000050: 00000000 00000000 00000000 00000000
[ 4.000027] host_regs: 00000060: 00000000 00000000 00000000 00000000
[ 4.006368] host_regs: 00000070: 00000000 00000000 00000000 00000000
[ 4.012710] host_regs: 00000080: 00000000 00000000 00000000 00000000
[ 4.019049] host_regs: 00000090: 00000000 00000000 00000000 00000000
[ 4.025391] cdns-ufshcd 4e84000.ufs: No record of pa_err
[ 4.030691] cdns-ufshcd 4e84000.ufs: No record of dl_err
[ 4.035992] cdns-ufshcd 4e84000.ufs: No record of nl_err
[ 4.041292] cdns-ufshcd 4e84000.ufs: No record of tl_err
[ 4.046592] cdns-ufshcd 4e84000.ufs: No record of dme_err
[ 4.051977] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[ 4.058142] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[ 4.063704] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3809412 us
[ 4.070822] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[ 4.076554] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[ 4.082373] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[ 4.087933] cdns-ufshcd 4e84000.ufs: No record of host_reset
[ 4.093579] cdns-ufshcd 4e84000.ufs: No record of task_abort
[ 4.674681] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 4.682033] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 4.689345] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 4.696662] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 4.704777] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.711695] of_cfs_init
[ 4.714148] of_cfs_init: OK
[ 4.726981] Waiting for root device PARTUUID=7aa8b068-02...
