SD Card Image for BBBW
Is there an SD Card image for BBBW similar to the Dec 5 or 18 testing images that have the wireless
changes for connecting to home wireless network using connman . I tried 2017-01-08 last night and it did not boot.
Maybe that image was just a testing image
Tom
I’ve been using the recent RCN 2017 images without any problem on my BBBW. I also use ConnMan to setup wireless. Maybe the image didn’t write correctly to your micro sd?
Images: https://rcn-ee.com/rootfs/bb.org/testing/
How I setup WiFi: https://www.ccoderun.ca/programming/2016-12-18_BBBW/index.html#wifi
Stéphane
Based on a post from RCN to Stephane I tried 2017-01-04 and the SD Card booted fine.
Tom
Yes, console or iot serve that purpose:
see the snapshot section:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
Thanks - I got the BBBW to run but why is it such a bear to get a root login on Debian.
I can access the machine with a “debian” login, then I used su to login as root, which works, but then,
when I try to login as user root with the same password I get “access denied.”
There's already enough "bot's" out their..
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#i_take_full_responsibility_for_knowing_my_beagle_is_now_insecure
This is for an embedded LAN without external connectivity where most apps run at uid=0 because they
must carry out privileged commands. Security is in 2048 bit encrypted comms and iptables.
