SD Cards For Beagleboard
What capacity is recommended for SD cards for the Beagleboard? This list
http://code.google.com/p/beagleboard/wiki/BeagleBoardShoppingList
says 2 Gb. Is that still recommended?
Can I use a micro SD card if it is in an SD card carrier?
Bob Cochran
uSD will work fine in an adpater and you can use pretty much any size card you want. There is no recommended SD card for Beagle per se. I am sure some folks may have had better luck with one brand versus the other. It really depends on what you can find at the right price.
I have 2 16GB cards I use, Kingston and bytestor.
Regards
Sid.
