How can i change NAND to search for uImage instead of uImage.bin? Also
my environment variables does not get saved in NAND, even though i do
#saveenv succcessfully!?
Does anyone know why keyboard and mouse does not work in uImage-2.6.29
build from OE?
Op 24 okt 2009 om 21:07 heeft Bhargav <bhargav1984@gmail.com> het
volgende geschreven:\
build from OE?
Your u-boot is probably too old.
regards
Koen
Thanks Koen. It fixed my problem, but why keyboard and mouse does not
work in uImage-2.6.29 build from OE?
It works over here for rev b6 and c3, both on ehci and otg.
Op 24 okt 2009 om 22:37 heeft Bhargav <bhargav1984@gmail.com> het
Hi
I had a similar problem when I tried building the latest uImage (I'd mentioned it on some of the previous post). I still have not managed to resolve the issue.
My USB otg and the serial port was not being detected by the uImage.
Is there some site/ftp/repo where the latest uImage, u-boot, etc are uploaded along with the root filesystem, so that newbies can get a working board configuration to start off with?
Kedar
Op 26 okt 2009, om 13:52 heeft Mavinkurve, Kedar IN BLR SISL het volgende geschreven:
Hi
work in uImage-2.6.29 build from OE?I had a similar problem when I tried building the latest uImage (I'd mentioned it on some of the previous post). I still have not managed to resolve the issue.
My USB otg and the serial port was not being detected by the uImage.Is there some site/ftp/repo where the latest uImage, u-boot, etc are uploaded along with the root filesystem, so that newbies can get a working board configuration to start off with?
