I'm working on connecting my beagleboard to another device over UART.
However, that device will only work with TTL logic.
So my question is: What is the voltage level of the second UART on the
expansion header of a BeagleBoard XM?
Also, with Angstrom, do I need to change some PINMUX settings to use
it?
I'm using a console-only build from Narcissus.
“CAUTION: The voltage levels on the expansion header are 1.8V. Exposure of these signals to a higher voltage will result in damage to the board and a voiding of the warranty.”
Thanks Jake for the quick reply!
I bought a USB to TTL serial converter suspecting this.
The idea was to get something that will allow me to use a PC or the
beagleboard.
I get the following error while building directly at my BeagleBoard:
make -C /lib/modules/2.6.32/build -I /media/sda1/cp210x-3.1.0/cp210x
M=/media/sda1/cp210x-3.1.0/cp210x modules
make: *** /lib/modules/2.6.32/build: No such file or directory. Stop.
make: *** [modules] Error 2
2. Uncommented the CONFIG_USB_SERIAL_CP210X line like:
CONFIG_USB_SERIAL_CP210X=m
3. Did a clean:
MACHINE=beagleboard ./oebb.sh clean
4. Copied the uImage file to the boot partition, made a backup of the
firmware and modules folders in /lib, deleted them and extracted the
modules archive there.
I got a new shiny 3.0 kernel but still no CP210x support! There's no /
dev/ttyUSB0 upon inserting the device.
Any pointers on what I did wrong?
