Second USB for PocketBeagle2: pinouts and configuration?
I had tried to connect second USB using pins 5,7,9,11,15 as described in some docs for PocketBeagle1. I have not found USB_ID for PB2 which is pin 13 on PB1. So far, no success. Does anybody know how to connect second USB for PB2 and what configuration steps must be done for having it working?
Connect it up with the exact same physical pins like the PocketBeagle 1 was and it’ll be USB host by default. (The USB pins are drop in exactly the same..)
Thank you for the answer! I did the same connection as for PB1 except the pin 13 isn’t connected to pin 15 because in PB1 it is called USB_ID, but pin 13 is GPIO0_36 in PB2. Should I connect 13,15 together as in PB1 case? Also do I need make any configuration changes on linux OS level?
Connect the same physical pins, the USB section PB2 was routed to be backwards compatible with older USB designs on the PB1.
I did all 6 pins (5,7,9,11,13,15) connected as for PB1 and still don’t see second USB. I guess there is something in PB2 configuration which I am missing?
Please share which usb host adapter you are using.
microUSB: example:
The techlab has a working usb HOST… capes/pocketbeagle/TechLab at main · beagleboard/capes · GitHub
Oh, I am using just USB socket without any additional chips. That is the reason, thank you!
These are some adapters we have used in the past
I don’t see any chips on the board, it looks like a micro-USB socket too.
i can’t find their ‘host’ version… i’ve use a OTG adapter with that design before to bring out a host port..
the extra chips are:
both are not required in a lab setup..
be careful with ESD while plugging in /out..
you could use one of these…
(links are all pointing to adafruit)
Ah yes, so just use a header for the usb, and then a readymade device. I was thinking it would be easier to get a small pcb board with a usb to Wi-Fi chip on it. Anyway although such chips exist I couldn’t find one already on a pcb.
Am I right that to have second usb recognized by OS you need to configure device tree for that? If yes, is there any working example of DT for PB2?
i just posted a link to the ACME wifi modul for exact that scenario:
no change needed when it comes to DT to get the additional USB(USB 1) to work.
Once USB1_DRVVBUS, USB1_D+, USB1_D-, USB1_VBUS is connected, simply plug in a USB device and the system will recognize it.
