HI,
I have set up the WiFi USB adapter in Beagleboard and I could surf internet from there. I just want some pointers on how to send message from beagleboard to phone or computer through IP. I am working on wireless ECG telemetry system. So once the signal processing is done, I want to publish the diagnosis results in a Smart phone? Would really like some help.
Thanks in adavnce,
Nasreen
You can consider using
http://www.zeromq.org
a higher level of abstraction that pure sockets.
Another approach might be implementing a webserver on the BB with
dynamic content. With eg. php you may even control (start/stop/....)
your ECG.
Dieter
Thanks guys…I will check them out…
@ Dieter Wirz: Btw Can You explain to me about web sever on bb ? How exactly to implent it?
Thanks guys...I will check them out....
to implent it?
I have to ask back: What was the question:
(i) "How to set up a web server on bb" or
(ii) "How to design a website running an ECG over a Webinterface"
A starting point for (ii) might be a webpage start.php containing the
lines below. It will start my_ecgprogram and print the returnvalue on
the screen of your Smartphone/Computer if you call it with your
webbrowser with http://bbs_ipadress/start.php
<?php
$ecgprogram = "/path/to/my_ecgprogram";
$output = shell_exec($ecgprogram);
echo $output;
Dieter
Both the questions actually…I dont know how to set up web severs in bb and how to design a website running on webinterface
Okay,
(i)
On Angstrom never tried, but you have to install a webserver
(lighthttp or apache2) and php. All should be available with opkg.
I use archlinux and ubuntu. Please Google for "archlinux lamp server"
or "ubuntu lamp server".
On Archlinux (I prefer Archlinux on bb) "pacman -S apache php
php-apache" should do the job. Then you can access your webserver.
(ii)
see below
Maybe you want check out running a Webserver first on you
desktop/laptop on a small (20Gb) partition of with
Ubuntu/Archlinux....
Dieter
For BB, i m using ubuntu 11.04,…so which websever is good ?
Ubuntu standard is Apache2
sudo apt-get install lamp-server^
don't forget the caret
Thanks alot…I will try tehm and will let you know if there are some issues…thanks
Hi Nasreen,
Have you been able to to send your ECG data to your phone? if so, could you please give me some pointers as to how you did this? I am currently working on sending data from a phone to the bbb to control gpios and would really appreciate the help.
Regards
Joshua
