Sending uImage on u-boot using serial
Hi Guys,
My question is a bit different on the way the beagleboard write the uImage on nand. In beagleboard, in order to write the uImage in flash is to boot the board on SD card and from there, it can access the nand for programming. The other way that I want to do is I want to send the uImage to u-boot using serial connection and I would like to know if it’s possible to do that?
Any theory?
John
Hi!
don’t know about BB but I did this on a different platform. I suppose the u-boot functionality is the same
Can you tell me how you did it?.
Yes, you can use kermit or xmodem over the serial connection. Or you can load raw s-record file.
Command you are looking for is “loadb”.
Check here: http://www.denx.de/wiki/view/DULG/UBootCmdGroupDownload#Section_5.9.5.3.
  • Juha
Thanks for the info.
john
