I’m looking to build a system to sense ‘steps’ of a hall-effect flowmeter.
My first throught is to use a voltage divider and rectifier circuit to get down to the 0-1.8v I need.
The problem I have is that every install may potentially have a different input voltage.
I’m wondering if there’s a simpler way to do this. I really only need to clip the voltage between 0-1.8v, it doesn’t matter if it spends 90% of it’s time clipped and throws away the negative half of the signal completely as I’m only interested in a count.
The current draw will be in the millivolt-range used by the adc input, so it shouldn’t need anything too heavy.
My first thought is a simple voltage regulator set to 1.8v, but I don’t know enough about them to know whether it’s a viable option or which to choose.
Any suggestions?
Hmm
Maybe a 1.8v zener ?
Or 1N4007’s in series = 1.4V
“No one could make a greater mistake than he who did nothing because he could do only a little.”
“All that is necessary for the triumph of evil is that good men do nothing” Edmond Burke (1729 - 1797)
http://www.packtpub.com/building-a-home-security-system-with-beaglebone/book
John,
Digital input, hadn’t thought of that but it makes sense, but I’m even less sure of myself in that arena…
I have to admit first my electronics knowledge is very rusty…
Maybe I can use a voltage divider after the diode/s to halve that 1.8v+ down to a safe 1.0v-ish.
My first thought here is to use a zener diode as in here http://www.electronics-tutorials.ws/diode/diode42.gif) with a voltage divider after.
Is the reverse voltage low enough to be safe with the BBB?
If not, what if I set up something like this, but make D_Z1 a normal diode so that the reverse current is completely stopped?
Again, not interested at all in the quality of the signal as long as I can determine the number of cycles.
Sorry for the electronics 101 questions, appreciate all your time.
Cheers,
Paul.
John,
Yeah, the reverse voltage will exceed the limits set on the ADC so a zener will not work for you. Here is a document that explains the principles that will help you.
http://www.ti.com.cn/cn/lit/an/sboa097a/sboa097a.pdf
Or search Google for "adc signal conditioning circuit” for more references.
John
John,
BTW, what is the flowmeter part number. Perhaps there is a much simpler way to interface this to the BBB.
John
John,
Cheers, it’s a Gicar 9.0.95.05g – sits in a cafe-style coffee machine, though this’ll only be the first install and the others may be different (but presumably similar) parts.
John,
OK, I couldn’t find a data sheet, but I think this is a three pin device, GND, POWER (4.5 - 20V) and PULSE. If this is correct, then all you need is a resistor divider as you suggested and a schmitt trigger to clean up the signal and then feed this directly into one of the GPIO pins. The schmitt trigger should be powered from VDD_3V3B and enabled with SYS_RESETn.
John
Yes, that sounds exactly like the device.
Awesome, didn’t even know such a beast existed. Will do my reading tonight.
Thanks again,
Paul.
http://www.ti.com/lit/an/scea046/scea046.pdf
Page 4 explains the concept.
John
I’ve had a bit of a dig on element14, this seems to fit the bill (http://au.element14.com/texas-instruments/sn74lvc1g14dbvr/ic-schmitt-trigger-inverter-smd/dp/1470878) but it’s not suitable for a breadboard prototype. You don’t know where I should be looking for a suitable prototyping product by any chance?
Paul.
Or you could use the part you selected and use this adapter:
http://au.element14.com/capital-advanced/33205/convert-from-5-sc-59-sc-74a-sot/dp/1654363
John
One more thing. If you do use this part with an adapter, don’t use any of the pins LCD_DATA[15…0] for GPIO or you board won’t boot. If you want to use any of these pins, you must use a schmitt trigger with an Output Enable (OE) pin, which you tie to the SYS_RESETn pin.
John
