Hi, I'm a new user trying to get set up for a Roomba project. Right
now I am connecting to the serial port on the beagleboard from an
RS-232 port on my host. Everything works when just booting the beagle
without an SD card. But if I load Angstrom (newest files for the
beagle demo from angstrom-distribution.org), everything prints fine up
to the login, then it gets weird. When I first type root, it always
shows up as ¹oot. I can delete it, and retype root <enter>, which is
when all the letters really go wrong. the prompt shows up as
"òïïô@båagìåbïaòdºþ# oot" and only these letters show up at all if I
enter them: "ab d gh k mn p s uv yz12 4 78 ". The rest are just
blank.
I can log into Angstrom via DVI monitor and USB hub, and the Angstrom
install seems fine.
Serial Angstrom login:
beagleboard login: ¹oot
I've tried putty and teraterm with the same results. I managed to get
it to work once, but I have not been able to repeat. I haven't been
able to find anything on this site or any others about serial working
until Angstrom logs in, so any assistance would be greatly
appreciated.
I'm _not_ a new user and I've also seen this on the latest Angstrom
demo. I don't see it on either the Sakoman r11 or home-built OE kernel/
root though, so I'd recommend you try that route. You might also try a
narcissus build.
Tested in Hyperterm and putty. Tried ANSI and VT100 terminal modes.
u-boot console works perfect both in printing and in user input
Angstrom prints perfect to console
Any user input in console seem to be damaged for a single input. If you type a sequence of characters then the first symbol is damaged, you backspace it and continue to enter characters. After that usually console begins to print rubbish. Anyway “reset” command fixes the console
blank.
The 5 second sleep seems to be different. That only effects the first
letter on wakeup.
I tried Angstrom-Beagleboard-demo-image-glibc-ipk-2009.X-
stable-20090612--beagleboard.rootfs.tar.bz2 and it starts out with the
same problem. Max, what do you mean by reset command? "Reset
terminal" in putty just clears the screen, and I can't type "reset,"
as only the s shows up. If I do a system reboot using the reset
button, then the serial terminal seems to work fine. At least it has
twice in a row now. Thanks!
I have always had trouble with screen and the beagleboard console on
my machine, this applies to every angstrom kernel .32 I have used so
far, downloaded or self compiled
Every now and then the output from the beagleboard freezes, but
characters sent to the beagleboard seem to be transmitted fine for a
while after the freeze. If I restart screen, the output resumes as
normal. This is a minor issue for me, but annoying nontheless.
On the newest demo image, the problem is a bit worse:
I feel the frequency of freezes is greater, and when I write (or
sometimes on the login prompt/ascii graphic) transmitted characters
appear garbled (lots of funny characters and ??). In many cases I can
type characters and communication will resume as normal after a while
- other times it is impossible for me to write anything more unless
performing a reset with the reset button on the board or powering it
down.
