I have a C program running on my beaglebone-black board that sends single character commands to a device that returns single ‘\r’ terminated strings. Occasionally, a different character goes over the wire than what was sent by the program. For example, the program may send a ‘T’ and occasionally a ‘X’ goes over the wire. The incorrect character sent isn’t a random character, it’s always a valid command that was sent several commands before.
As an experiment, I wrote a simple program that sends characters ‘0’-‘9’ over and over. Occasionally I see a character that is out of order. For example, ‘8’ is sent instead of ‘5’. If I change the program to send ‘a’-‘z’ and re-run it, I may occasionally see ‘0’-‘9’ go over the wire instead of ‘a’-‘z’ at first, but eventually all of the incorrect characters sent over the wire are in the range of ‘a’-‘z’.
All of these clues point to an issue with the serial driver. I’m using UART4 and running 4.4.70-bone-rt-r17.
The serial port path is “/dev/ttyS4”. The C code is base on termios.h (i.e. using open(), write(), read(), etc). I’m not decoding anything. In the experiment described above, I have a loopback jumper wire connecting TX to RX. I open() the port, write() a character, then read() character, and occasionally don’t get back what I sent.
This commit describes what I’m seeing, but I patched 8250_omap.c driver and it doesn’t fix my problem.
My baud rate is 9600bps. I’m running 4.4.70-bone-rt-r17, which is a RT kernel.
It turns out the commit above DOES fix my problem. I initially only replaced the modules on the board and rebooted. For some reason that didn’t work. I ended up replacing everything (kernel, modules, firmware, dtbs) and it works now.
