Hello
I’m using the debian image made for this LCD cape:
https://www.tigal.com/product/3526
I’m using this image:
http://www.chipsee.eu/index.php?option=com_jdownloads&Itemid=204&view=viewdownload&catid=18&cid=72
I’m trying to use different RS232 com ports:
If I try to use the /dev/ttyO1 (the D rs232 connectors labeled COM 1) I can’t communicate with my device using HamLib.
If I try to connect a FTDI USB RS232 cable, I can’t see the /dev/ttyUSB port…
If I type:
debian@beaglebone:~$ modprobe ftdi_sio
libkmod: ERROR …/libkmod/libkmod.c:505 kmod_lookup_alias_from_builtin_file: could not open builtin file ‘/lib/modules/3.8.13-00720-g4202df2-dirty/modules.builtin.bin’
FATAL: Module ftdi_sio not found.
can someone help me?
thanks
Giorgio
