Hello!
I made an own devicetree and can enable with:
echo high > gpio75/direction
But how can I made this automatic on system boot?
Thank you!
Hello!
Thank you!
'man 5 crontab' then search for reboot is probably easiest.
Britton
Hello
I found a Option in the device tree configuration.
There I can set as output.
Thank you
Hi fiambs
Did you get this to work? If so, what settings did you use in the Device Tree? Can you please post a summary?
The reason I ask is that I also tried to set the output pin initial state in the Device Tree but after a short while of not getting it to work I put it to one side for another day. Knowing what you did will save me some time.
