setting up android gingerbread on the bone
I'm following the steps outlined at
http://processors.wiki.ti.com/index.php/BeagleBone-Android-DevKit_Guide#Installation_and_Usage
to install gingerbread on my beagle bone (which has a dvi cape
installed). the card created with no problems. on my ubuntu host I'm
having difficulty getting a serial console set up after connecting the
bone usb and doing the following:
$ sudo modprobe ftdi_sio vendor=0x0403 product=0xa6d0
$ minicom -D /dev/`dmesg | grep FTDI | grep "now attached to" | tail
-n 1 | awk '{ print $NF }'`
the last line gives an error /dev/ttyUSB0 Device or resource busy.
How can I tell why it's busy and what is making it busy so as to
correct the problem?
Eric
You could try
dmesg | grep ttyUSB
it should give you some clue.
or you could try more complex solution, which is described here:
http://stackoverflow.com/questions/9183880/how-to-find-out-which-usb-rs232-device-is-on-which-tty
Best regards
Rok
