Hello!
I’ve been able to install CCS and the PRU compiler tools to my ubuntu desktop. I’ve been following this tutorial: http://processors.wiki.ti.com/index.php/PRU_Training:_Hands-on_Labs", However I am stuck on the “Linux Processor SDK” part. I’m assuming it’s supposed to be installed on the BeagleBone, but all the tutorials for it seem to act like it’s some kind of OS or it’s loading files from your computer when it boots or something. I thought there was some sort of cape-overlay that I am supposed to use.
Where to I go from here?
Alek
Hello!
I do my PRU developement natively.
https://gist.github.com/jadonk/2ecf864e1b3f250bad82c0eae12b7b64
Everything seems to work up until:
debian@beaglebone:/var/lib/cloud9/2ecf864e1b3f250bad82c0eae12b7b64$ sudo config-pin p9.30 pruout
P9_30 pinmux file not found!
bash: /sys/devices/platform/ocp/ocp*P9_30_pinmux/state: No such file or directory
Cannot write pinmux file: /sys/devices/platform/ocp/ocp*P9_30_pinmux/state
I am running bone-debian-9.2-iot-armhf-2017-11-02-4gb.img rather than https://rcn-ee.com/rootfs/bb.org/testing/2017-06-11/stretch-iot/bone-debian-stretch-iot-armhf-2017-06-11-4gb.img.xz because it appears that the download link is not there.
Other than that every other command worked.
debian@beaglebone:/sys/devices/platform/ocp$ ls
40300000.ocmcram 44e35000.wdt 48044000.timer 48060000.mmc 481ae000.gpio 49000000.edma 4a300000.pruss driver_override ocp:l4_wkup@44c00000
40302000.ocmcram_nocache 44e3e000.rtc 48046000.timer 480c8000.mailbox 481d8000.mmc 49800000.tptc 4c000000.emif modalias of_node
44e07000.gpio 47400000.usb 48048000.timer 480ca000.spinlock 48200000.interrupt-controller 49900000.tptc 53100000.sham ocp:P9_19_pinmux power
44e09000.serial 48038000.mcasp 4804a000.timer 4819c000.i2c 4830e000.lcdc 49a00000.tptc 53500000.aes ocp:P9_20_pinmux subsystem
44e0b000.i2c 48042000.timer 4804c000.gpio 481ac000.gpio 48310000.rng 4a100000.ethernet 56000000.sgx ocp:cape-universal uevent
I noticed that USR0 was blinking at a steady rate that was not 5 blinks per second it is supposed to. (After I ran sudo make run). There was no way to make it stop blinking with the /sys/class/leds/ commands. I restarted the beaglebone and was able to control whether it did a heartbeat/none with trigger, but after I ran “sudo make run” it did the blinking again.
I changed the hello-pru.c so that the INS_PER_US was 50 instead of 200 and recompiled and it appears to be blinking four times as fast, so the PRU is controlling the LED without having to run “sudo config-pin p9.30 pruout.”
P9_30 = hdmi audio
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
So you add:
disable_uboot_overlay_audio=1
to /boot/uEnv.txt
> directory
P9_30_pinmux/state
P9_30 = hdmi audio
Beagleboard:BeagleBoneBlack Debian - eLinux.org
So you add:
to /boot/uEnv.txt
I hit this but for a different reason - I got a pocket beagle a few days
ago.
I had a look at /usr/bin/config-pin.
Would I be correct that to translate P9_30 to pocket beable,
on a BBB(assuming that's what the steps are targeted at) P9_30 is pru pin
144
so the equivalent on pocket beagle is P2_32 ?
eg.
$ sudo perl /opt/scripts/device/bone/show-pins.pl -v | grep P9.30
P9.30 102 D12 fast rx down 7 gpio 3.16
ocp/P2_32_pinmux (pinmux_P2_32_default_pin)
Either way, how would I map any of these IDs to the pinout/ expansion
headers diagram?
Looks like show-pins (GitHub - mvduin/bbb-pin-utils: Pin utilities for BeagleBone Black) supports
BBB.
It confused me at first that P8 and P9 were being reported.
Is is something that could be enahnced to support the pocket beagle?
Thanks in advance,
Alex
directory
P9_30 = hdmi audio
So you add:
to /boot/uEnv.txt
Looks like I chose a bad pin for a good default demo. This is a different pin than used for the on-board LED. I tried to show both a PRU GPIO (via p9.30) and an OCP GPIO via the on-board LED.
So, the LED still blinks because it is a different line that is controlled via the OCP GPIO rather than the PRU GPIO.
Looks like I adjusted the rate without updating the README.md. I also tried to add a mode that allows for a “decay” where the cycles between toggles gets shorter and shorter. With that mode, you can see a bit more of the power of the PRU to toggle pins quickly, although you quickly get to a point where you’d need a scope to see how fast the PRU is toggling the GPIO.
Right. Because the PRU is controlling the GPIO and not Linux, the /sys/class/leds interface wouldn’t stop it from toggling. However, you might note that Linux might still set or clear the LED at times, so both Linux and the PRU can collide with each other. That’s why my instructions say to set the trigger to “none”.
As mentioned elsewhere on this thread, p9.30 is for the PRU GPIO and the USR0 LED is controlled via an OCP GPIO. PRU GPIOs can be controlled much faster, but the LEDs aren’t connected to pins that have pruout modes. My example illustrated toggling both an OCP GPIO and a PRU GPIO. PRU GPIOs can be set with registers directly in the PRU core rather than needing to write to an OCP (on-chip-peripheral) memory address.
Hello everyone, I’m trying to run an example of PRU to flash a led and I’m using P9_41 and P9_27, but to no working.
Can someone help me?
I created a dts and accredited that is correct, see the output of the show-pins.pl script:
P9.31 / hdmi audio clk 100 A13 fast rx down 7 gpio 3.14 P9.29 / hdmi audio fs 101 B13 fast rx down 7 gpio 3.15 P9.30 102 D12 fast rx down 7 gpio 3.16 P9.28 / hdmi audio data 103 C12 fast rx down 7 gpio 3.17 P9.42b 104 B12 fast rx down 7 gpio 3.18 **P9****.27** 105 C13 fast 7 gpio 3.19 pruss@4a300000 (pinmux_pru_pru_pins) **P9****.41** 106 D13 fast 7 gpio 3.20 pruss@4a300000 (pinmux_pru_pru_pins) P9.25 / audio osc 107 A14 fast rx down 7 gpio 3.21 P9.41 / jtag emu3 109 D14 fast rx down 7 gpio 0.20
Here my DTS:
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/pinctrl/am33xx.h>
// This determines which boards can use this DTS overlay
compatible = “ti,beaglebone”, “ti,beaglebone-green”, “ti,beaglebone-black”;
// I think part-number is supposed to correspond with the filename,
// so we’d save this as “PRU-GPIO-MTV-00A0.dts”.
part-number = “PRU-GPIO-MTV”;
version = “00A0”;
exclusive-use =
“P9.41”, “P9.27”, “pru0”;
fragment@0 {
target = <&am33xx_pinmux>;
overlay {
example_pins: pinmux_pru_pru_pins {
pinctrl-single,pins = <
0x1a8 0x0f
0x1a4 0x0f
// This enables the PRU and assigns the GPIO pins to it for use in EGP mode.
fragment@1 {
target = <&pruss>;
overlay {
status = “okay”;
pinctrl-names = “default”;
pinctrl-0 = <&example_pins>;
