I received my BB Black Wireless yesterday and I do not see any doc on how to set up
wireless for my home network.
USB 192.168.7.2 network works and Cloud9 there gets a terminal.
I tried my usual editing of /etc/network/interfaces with my said and psk for wlan0 but it did not connect.
I found a thread on Beagelbone Black section with something to try
nah use connman, i have it installed by default on jessie images.
~$ sudo connmanctl
enable wifi
Enabled wifi
scan wifi
Scan completed for wifi
services
*AO Wired ethernet_74d435b65be6_cable
Avenger wifi_14cc201db6f6_4176656e676572_managed_psk
agent on
Agent registered
connect wifi_14cc201db6f6_4176656e676572_managed_psk
Agent RequestInput wifi_14cc201db6f6_4176656e676572_managed_psk
Passphrase = [ Type=psk, Requirement=mandatory ]
Passphrase? wine n dine
Connected wifi_14cc201db6f6_4176656e676572_managed_psk
quit
check:
sudo ifconfig -a
Reflash with this image:
https://rcn-ee.net/rootfs/bb.org/testing/2016-12-05/lxqt-4gb/
In the version you have, I had setup the wl18xx in tether mode,
however this doesn't work the greatest when no eth0 device is
available..
In 2016-12-05, the wl18xx is setup by default as an access point,
which you can ssh into, and then use connmanctl to connect to a real
AP. (while still being connected to it's AP over ssh)..
If you plug in a usb-eth adapter, it'll default back to the previous
tether mode.
(this change in 2016-12-05, is for bbbw users to hopefully give a
better wifi out of box experience)..
OK IT WORKS NOW
I attached a terminal dump from cloud9 showing what steps I took as
well as a Mac Terminal after Rebooting.
One question is in /etc/network/interfaces there is a comment
##connman: WiFi
TermDec5WifiWorks.txt (3.7 KB)
WifiDec5fixCld9.txt (3.46 KB)
So, "tether wifi disable" is needed when connman is in control of the
tether'ing. (<tether> interface shown by sudo ifconfig -a)
With 2016-12-05 and future images, /usr/bin/bb-wl18xx-tether is
controlling it. (<SoftAp0> interface shown by sudo ifconfig -a)
Main differences:
connman tether <tether> : Allows one AP connection, nice for making a
router (when you have a usb-ethernet interface)
/usr/bin/bb-wl18xx-tether <SoftAp0> : Allows one AP and a second WiFi Connection
btw, one issue with this new setup, WiFi is slower with the dual
connections, in my testing switching from v4.4.x -> v4.9.x saw an
increase from 55kb/s -> 1,600kb/s
$ cd /opt/scripts/tools/
$ git pull
$ sudo ./update_kernel.sh --ti-kernel --lts-4_9
connections, in my testing switching from v4.4.x → v4.9.x saw an
increase from 55kb/s → 1,600kb/s
$ git pull
Did I bonk my BBB by updating my kernel with this recipe 6 months later?
The device boots up but messages of “direct firmware load for am335x-pru0-fw failed with error -2” are written to console. “ifconfig” freezes the command line and can no longer ssh in via wlan0.
I’ll look into it more carefully later. BBB and bonehead error.
#uname -a
Linux beaglebone 4.9.25-ti-r32 #1 SMP PREEMPT Fri May 5 19:10:28 UTC 2017 armv7l GNU/Linux
Thanks.
$ git pull
It "shouldn't" right now as the only developers behind "--ti-kernel
--lts-4_9" is ti.com, at this point i'm just rebasing to keep the same
setup..
The device boots up but messages of "direct firmware load for am335x-pru0-fw
failed with error -2" are written to console.
This is normal, and ported from teh --lts-4_4 branch by ti.com, it's
the pru interface. You as the end user have the abilty to load two pru
firmwares and run what ever you want on the pru.
"ifconfig" freezes the command
AH this is odd.. I'll look into this tomorrow..
I'll look into it more carefully later. BBB and bonehead error.
#uname -a
armv7l GNU/Linux
A little more data in case useful.
By isolating ifconfig in a separate screen window, it appears that ifconfig process starts but does not return and is not using any CPU. Similarly for “ip link show” and “ip a”.
root@beaglebone:~# cat /proc/net/dev
Inter-| Receive | Transmit
face |bytes packets errs drop fifo frame compressed multicast|bytes packets errs drop fifo colls carrier compressed
usb0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
wlan0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
usb1: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
lo: 25280 320 0 0 0 0 0 0 25280 320 0 0 0 0 0 0
The commands “service networking stop/start” do return after timing out and leaving systemd messages like this:
May 9 00:46:05 beaglebone systemd[1]: Starting Raise network interfaces…
May 9 00:51:05 beaglebone systemd[1]: networking.service: Start operation timed out. Terminating.
May 9 00:51:05 beaglebone systemd[1]: Failed to start Raise network interfaces.
May 9 00:51:05 beaglebone systemd[1]: networking.service: Unit entered failed state.
May 9 00:51:05 beaglebone systemd[1]: networking.service: Failed with result ‘timeout’.
Finally, there is this message in syslog:
May 8 23:33:43 beaglebone systemd-udevd[566]: seq 2224 ‘/devices/platform/ocp/47810000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18xx.1.auto/net/wlan0’ killed
